1999 Z71 P0300 P0102 P0157
chris001979
Hello i have a 1999 chevy z71 159k miles started missing took it to t he chevy garage all they could tell me was it was throwing a P0300 code they couldn't tell what was causing it they said it was an injector or an o2 sensor and for me to take my pic but they couldn't guarantee this would fix it so i just don't drive it but now i need it so i dusted it off fired it up and drove it for a day and it runs fine as long as you floor it the faster you go the better it runs took it to advanced hooked it up and it through these codes P0102 mass airflow sensor low input P0157 o2 sensor #2 bank#2 and P0300 but didn't state what cylinders were missing so my question is can a bad a bad mass airflow sensor make a car run like this and if it was bad wouldn't the truck run different if i unplugged it. The truck idles low when warmed up like 500 range and you can feel the miss the most at idle and moderate acceleration if you just nail it the truck will run like a beast any ideas would be great
  • Replies 39
Read about the MAF sensor....If it is not operating properly it can screw up your air/fuel mixture. Lean or rich and noticeable fuel milage depreciation.
Go to the wreckers and try a used one (cheap). New ones are expensive so this could be a troubleshoot way. Since you have a 99 should be able to pick one up.
Scooby (don't throw good money for something that the mechanic is guessing at when he diagnosed your codes)
Hey Govtec4 , at least he tried a chevy garage !!
ya he did ,to bad its a shit garage ,,,,
anywho ,buy a spray cleaner for sensors ,use an ear q-tip and clean the sensor CAREFULLY ,,both sides by bending the q-tip ,,,,be carefull ,that should raise the idle ,,,it worked for me at work ,,,,
what about the 02 sensor code? ,is it a perf code ?,the position of the sensor is not the full code title ,please elaborate as i dont want to look it up lol
misfire is not pointing at a cylinder yet ,,,,throw a fuel filter at it for giggles and measure pressure also to start ....
14 yr old truck out of moth balls ,,,,sure we can fix it ,,,,
omg ,what happened with the 2 posts ????? ,it did refresh lmao !!!!
Yeah i can't remember what all it said about the o2 sensor just think it said it was bad but a buddy told me that o2 sensor 2 bank 2 was after the cat and should not make it run bad when i changed the water pump i was not friendly with the air filter lid and hose the mass airflow sensor was left hooked up and im sure it was banged around a bit none the less i had the problem before it every threw the code for the mass airflow sensor i don't
Yeah i can't remember what all it said about the o2 sensor just think it said it was bad but a buddy told me that o2 sensor 2 bank 2 was after the cat and should not make it run bad when i changed the water pump i was not friendly with the air filter lid and hose the mass airflow sensor was left hooked up and im sure it was banged around a bit none the less i had the problem before it every threw the code for the mass airflow sensor i don't want to just dump money at random problems
I had it un hooked when i changed the water pump and clutch fan last weekend and it didn't make a difference with it or with out it truck ran the same
Well, now you know why the Engine light is on and you are having codes.
The sensors are not needed to drive your truck, Just as long as the Radio Works eh!!!
I had them.reset and they come back horrible misfire unless you have it floored then it runs great idles at 500 and feels like the motor is caming out shakes the whole truck
i did the listen to the injector trick with a screw driver and injector number 8 is hardly working at all sounds way differnt than the rest and number 4 didnt sound to healthy im thinking with 2 bad or weak injectors and a bad mass airflow sensor this could be why the truck isnt running very good any more info would be great and thanks for all your guys input
New fuel filter fuel preasure is good or with in specs right at the 60 lbs mark just was thinking that the cheap scaner tool at advanced wouldn't pin point what cylinders were missing and since the chevy garage did say it was an injector or o2 oh and i replaced the MAF No help
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
