1999 Z71 P0300 P0102 P0157
chris001979
You arent cooling the brake lines enough
  • Replies 39
Sorry I was bored in class. Lighten up a little. I'm in the same boat as you with the P0300.
Do you have a buddy with a 99-02 V8 truck or SUV? Doesn't matter if its Chevy or GMC. If so swap in their MAF and see if it eliminates the P0102.
For the P0157 I would just replace the O2 sensor.
And the P0300.... when were the plugs and wires last replaced? This can be caused by the MAF, a catalytic converter, coil pack, injector, or a combo.
My mom's G6 had a catalytic converter fail and it caused 5 codes to pop. A MAF code, a catalytic converter code, secondary air injection code, P0300, a body code. Changing the catalytic converter resolved all those codes
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Sorry just so frustrating i am 100% sure number.8 injector is failed i did the listen to the injectors trick and number is very quit sound like it has failed i know the mass airflow sensor is bad and i have a bad 02 sensor im pretty sure if i fix these 3 things it will fix it
Do them one at a time and clear codes after each to see what codes come back. Let us know the results
Update i pulled the fuel rail of the passenger side and omg the number 8 injector was completely clogged up so i took all 4 out cleaned them up and bingo she is running slot better tomorrow I do the driver side
How did you clean them? I am going to clean my MAF, TB, and now maybe the injectors.
you can blow air across the top of the injector and vacumn will suck the debris off the top ,or a wet vac ,,,,,
there is a screen at the top
