dtc code list
casale33
does anyone have complete list of body codes i have some codes come on and i keep getting different conflicting descriptions of there meanings as per b0012 b0013 b0079 b0080 boo52 thanks 2011 silverado
have warranty left?
What does boo79 &80 mean discard sis sensor and wrong sensor it was never changed or messed with ! Thanks
Circuit/System
Description
The seat position sensor is used to determine the proximity of a front driver
or passenger seat position with respect to the frontal air bag. There are two
states of seat position, forward and rearward. The seat position sensor
interfaces with the Inflatable Restraint Sensing and Diagnostic Module (SDM) and
allows the Inflatable Restraint Sensing and Diagnostic Module to disable stage 2
of the frontal air bag for a front seat that is forward of the forward/rearward
point in seat track. The seat position sensor provides 2 current ranges, one
range for the forward seat position and one for rearward seat position. When the
Inflatable Restraint Sensing and Diagnostic Module receives input from a seat
position sensor that the seat is rearward, and the Inflatable Restraint Sensing
and Diagnostic Module will not disable stage 2 deployment. When the seat is
forward, the Inflatable Restraint Sensing and Diagnostic Module will disable
stage 2 deployment. The Inflatable Restraint Sensing and Diagnostic Module
monitors the seat position sensor circuit and if a fault is detected, the
Inflatable Restraint Sensing and Diagnostic Module will set code B0079 or B0080
and disable stage 2 frontal deployment.
Circuit/System Testing
Note: When removing connectors, inspect for damage or corrosion.
Damage or corrosion in the following requires repair or replacement of the
affected component/connector:
  • Seat position sensor
  • Inflatable Restraint Sensing and Diagnostic Module
  • Seat position sensor wiring harness connector
  • Inflatable Restraint Sensing and Diagnostic Module wiring harness
    connector
  1. Ignition OFF, disconnect the harness connector at the
    appropriate seat position sensor.
  2. Test for less than 10 Ω between the low reference circuit
    terminal 1 and ground.
    • If 10 Ω or greater
    1. Disconnect the X2 harness connector at the Inflatable
      Restraint Sensing and Diagnostic Module.
    2. Test for less than 2 Ω in the low reference circuit end to
      end.
      • If 2 Ω or greater, repair the open/high resistance in the
        circuit.
      • If less than 2 Ω, replace the Inflatable Restraint Sensing
    • If less than 10 Ω
  3. Ignition ON, test for 4–9 V between the signal circuit
    terminal 2 and ground.
    • If less than 4 V
    1. Ignition OFF. Disconnect the X2 harness connector at the
      Inflatable Restraint Sensing and Diagnostic Module.
    2. Test for infinite resistance between the control circuit and
      ground.
      • If less than infinite resistance, repair the short to ground
        on the circuit.
    3. Test for less than 2 Ω in each control circuit end to
      end.
        circuit.
    • If greater than 9 V
    1. Ignition OFF, disconnect the X2 harness connector at the
      Inflatable Restraint Sensing and Diagnostic Module. Ignition ON.
    2. Test for less than 1 V between the control circuit and
      ground.
      • If 1 V or greater, repair the short to voltage on the
        circuit.
      • If less than 1 V, replace the Inflatable Restraint Sensing
    • If within the specified range
  4. Replace the Seat Position Sensor.
this doesnt come out very good after pasting
    connector
      end.
        circuit.
    • If less than 10 Ω
    • If less than 4 V
      ground.
        on the circuit.
      end.
        circuit.
      ground.
        circuit.
gok great info thanks will post back after checking wiring
just to follow up on .. check wiring ok , ordered seat poss sensor, installed and it cleared b0079 code.. thanks for info.. still have b0012 b0013 code, i check connections to pass front air bag, seem ok are those codes def for front/pass deployment loop stage 2 or have they been switched around thanks
Cause
This condition may be caused by a loose, missing, or damaged connector
position assurance (CPA) retainer at a supplemental inflatable restraint (SIR)
module electrical connector, or a deployment loop wiring harness electrical
connector.
this is from the a bulletin ,,,check this ,i will post the DTC if ya want
let me know
these codes are for steering wheel air bag only stages 1 and 2
DTC B0012 or B0013
Diagnostic Instructions
DTC Descriptors
DTC B0012 01
Driver Steering Wheel Air Bag Deployment Loop Stage 1 Short to
Battery
DTC B0012 02
Ground
DTC B0012 04
Driver Steering Wheel Air Bag Deployment Loop Stage 1 Open
DTC B0012 0D
Driver Steering Wheel Air Bag Deployment Loop Stage 1 High
Resistance
DTC B0012 0E
Driver Steering Wheel Air Bag Deployment Loop Stage 1 Low Resistance
DTC B0013 01
Driver Steering Wheel Air Bag Deployment Loop Stage 2 Short to
Battery
DTC B0013 02
Ground
DTC B0013 04
Driver Steering Wheel Air Bag Deployment Loop Stage 2 Open
DTC B0013 0D
Driver Steering Wheel Air Bag Deployment Loop Stage 2 High
Resistance
DTC B0013 0E
Driver Steering Wheel Air Bag Deployment Loop Stage 2 Low
Resistance
Diagnostic Fault
Information
Circuit
Short to Ground
High Resistance
Open
Short to Voltage
Signal Performance
Driver Steering Wheel Air Bag Stage 1 High Control
B0012 02, B0012 0E
B0012 0D
B0012 04, B0012 0D
B0012 01
Driver Steering Wheel Air Bag Stage 1 Low Control
B0012 02, B0012 0E
B0012 0D
B0012 04, B0012 0D
B0012 01
Driver Steering Wheel Air Bag Stage 2 High Control
B0013 02, B0013 0E
B0013 0D
B0013 04, B0013 0D
B0013 01
Driver Steering Wheel Air Bag Stage 2 Low Control
B0013 02, B0013 0E
B0013 0D
B0013 04, B0013 0D
B0013 01
Circuit/System
Description
During a frontal crash of sufficient force the inflatable restraint sensing
and diagnostic module (SDM) will allow current to flow through the deployment
loop in order to deploy the steering wheel air bag. The inflatable restraint
sensing and diagnostic module performs continuous diagnostic tests on the
deployment loops to check for proper circuit continuity and for shorts to ground
or voltage. There are 2 shorting bars used within the steering wheel air bag
coil connector which will short together both steering wheel air bag stage 1
high control circuit and steering wheel air bag stage 1 low control circuit and
both steering wheel air bag stage 2 high control circuit and steering wheel air
bag stage 2 low control circuit when the connector is disconnected. This will
help to prevent unwanted deployment of the steering wheel air bag during
servicing.
Conditions for Running the
DTC
Ignition voltage is between 9–16 V.
Conditions for Setting the
DTC
B0012 01 stage 1 or B0013 01 stage 2
The steering wheel air bag deployment loop is shorted to voltage for
2 seconds.
B0012 02 stage 1 or B0013 02 stage 2
The steering wheel air bag deployment loop is shorted to ground for
2 seconds.
B0012 04 stage 1 or B0013 04 stage 2
The steering wheel air bag deployment loop is open for 2 seconds.
B0012 0D stage 1 or B0013 0D stage 2
The steering wheel air bag deployment loop resistance is greater than 4.4 Ω
for 2 seconds.
B0012 0E stage 1 or B0013 0E stage 2
The steering wheel air bag deployment loop resistance is less than 1.7 Ω for
2 seconds.
Action Taken When the DTC
Sets
  • The inflatable restraint sensing and diagnostic module requests the
    instrument cluster to illuminate the AIR BAG indicator.
  • The inflatable restraint sensing and diagnostic module will store a DTC,
    however if an event occurs the system will still attempt deployment.
Conditions for Clearing the
DTC
  • The condition for setting the DTC is no longer exists.
  • A history DTC will clear once 100 malfunction-free ignition cycles have
    occurred.
Diagnostic Aid
Note: The following diagnostic aids apply for both current and history
DTCs.
A worn steering wheel air bag coil can cause a repeated history DTC to set.
To verify this condition, turn the steering wheel 360 degrees in one direction
then back 360 degrees in the other direction, multiple times, while viewing the
scan tool Deployment Loop Resistance parameters.
An incorrectly installed connector position assurance (CPA) or incorrectly
seated connector can cause a shorting bar to short both control circuits
together. Check the connectors and CPAs if a DTC with symptom byte 02 or 0E is
set, to ensure the shorting bars are not causing the circuits to be shorted
together. Shorting bars are used in the locations listed below:
  • Steering wheel air bag assembly
  • Steering wheel air bag coil assembly
  • Inline harness connectors
  • Harness side of the inflatable restraint sensing and diagnostic module
    connector
Terminal fretting or incorrectly seated connector can cause an open/high
resistance condition. Check the circuit terminals for fretting or incorrectly
seated connector if a DTC with symptom byte 04 or 0D is set.
Reference Information
Schematic Reference
SIR
Schematics
Connector End View Reference
Component
Connector End Views
Description and Operation
Supplemental
Inflatable Restraint System Description and Operation
Electrical Information Reference Scan Tool Reference
Control
Module References
for scan tool information
Special
Tools
EL-38125-580 Terminal Release Tool Kit
Circuit/System
Verification
Note:
  • Refer to SIR Service
    Precautions
  • Inspect all terminals for damage or corrosion when disconnecting connectors.
    affected component/connector.
    • Driver steering wheel air bag
    • Driver steering wheel air bag coil
    • Inflatable restraint sensing and diagnostic module
    • Air bag wiring harness connector
    • Inflatable restraint sensing and diagnostic module wiring harness
      connector
  • The connector and connector position assurance (CPA) may seat independent of
    each other. Both the connector and CPA should seat with an audible and/or
    tactile click. The CPA isolates the shorting-bars within the connector allowing
    the deployment circuit to operate properly. Replace any CPA that is damaged or
    missing.
  • If the condition is intermittent or cannot be duplicated, disconnect the
    connectors and add dielectric grease / lubricant (Nyogel 760G or equivalent,
    meeting GM specification 9986087). This procedure will correct the high
    resistance condition due to terminal fretting corrosion.
  1. Verify the appropriate scan tool Deployment Loop Resistance
    parameters stay consistently between 2.1–4.0 Ω without any spikes or dropouts
    while turning the steering wheel 360 degrees in one direction then back 360
    degrees in the other direction.
    • If less than 2.1 Ω or greater than 4.0 Ω
      Refer to Circuit/System Testing.
    • If there are spikes or dropouts
      Replace the steering wheel air bag coil.
    • If between 2.1–4.0 Ω without any spikes or
      dropouts
  2. Verify DTC B0012 or B0013 is only set as a history DTC.
    • If the DTC is set as current
    • If the DTC is set as history
  3. Verify the scan tool Deployment Loop Resistance parameters
    stay consistently between 2.1–4.0 Ω without any drop outs or spikes while moving
    the harness near each connector listed below.
    • Steering wheel air bag.
    • Any inline harness connector
    • If the reading is erratic while moving the
      harness, perform the following
    • Inspect each connector terminal for damage or corrosion and repair as
      necessary.
    • Apply dielectric grease / lubricant (Nyogel 760G or equivalent, meeting GM
      specification 9986087) to each connector terminal.
    • Ensure each connector and CPA is correctly seated.
      dropouts
  4. All OK.
  1. Ignition OFF, disconnect the scan tool and disconnect the
    appropriate harness connector listed below at the steering wheel air bag. It may
    take up to 2 minutes for all vehicle systems to power down.
    • DTC B0012 connector X1
    • DTC B0013 connector X2
  2. Test for greater than 25 Ω between the control circuit
    terminal 1 and the control circuit terminal 2.
    • If 25 Ω or less
    Note: Some connectors may be equipped with shorting bars as a safety
    component to prevent accidental inflator deployment. When testing on a connector
    with shorting bars, the shorting bars must be disabled to ensure accurate test
    results. Insert an appropriate pick from EL-38125-580 and depress the shorting
    bars above the appropriate terminals. This will lift the shorting bar from the
    terminal and allow accurate test results. Take care not to damage the connector,
    shorting bar, or terminal when depressing the shorting bar.
    1. Disconnect the X1 harness connector at the inflatable
      restraint sensing and diagnostic module.
    2. Test for infinite resistance between the two control
      circuits.
      • If less than infinite resistance, repair the short between
        the two circuits.
      • If infinite resistance, replace the inflatable restraint
    • If greater than 25 Ω
  3. Ignition ON.
  4. Test for less than 11 V between each control circuit
    terminal listed below and ground:
    • Control circuit terminal 1
    • Control circuit terminal 2
    • If 11 V or greater
    1. Ignition OFF, disconnect the X1 harness connector at the
      inflatable restraint sensing and diagnostic module, ignition ON.
      ground.
        circuit.
      • If less than 1 V, replace the inflatable restraint sensing
    • If less than 11 V
  5. Ignition OFF.
  6. Test for greater than 25 Ω between each control circuit
    • If 25 Ω or less
      ground.
        on the circuit.
  7. Install a 3 A fused jumper wire between the control circuit
    terminal 1 and the control circuit terminal 2, ignition ON.
  8. Verify the scan tool Deployment Loop Resistance parameter is
    consistently less than 2 Ω while turning the steering wheel 360 degrees in one
    direction then back 360 degrees in the other direction.
    • If the reading is erratic while turning the
      steering wheel
      Replace the steering wheel airbag coil.
    • If 2 Ω or greater
      inflatable restraint sensing and diagnostic module.
    2. Test for less than 2 Ω in the steering wheel airbag coil and
      each control circuit end to end.
      • If 2 Ω or greater, replace the coil or repair the open/high
        resistance in the circuit.
      • If less than 2 Ω, replace the inflatable restraint sensing
    • If less than 2 Ω
  9. Ignition OFF, connect the harness connector at the steering
    wheel air bag, press in the CPA (if equipped) until an audible and/or tactile
    click is heard.
  10. Ignition ON, clear DTCs. Operate the vehicle within the Conditions for
    Running the DTC.
  11. Verify DTC B0012 or B0013 is not set.
    • If DTC B0012 or B0013 is set
      Replace the steering wheel air bag.
    • If DTC B0012 or B0013 is not set
  12. All OK.
ok thanks,, i originally started looking at the drivers side for the fault, checking connectors ect,even changed clock spring for the hell of it even tho it ring out but then i seen numerous gm posted dtc list referring b0013 ,12 to the pass/frt right air bag....so ill go back to the driver/steering wheel air bag and thoroughly check with your provided instructions ..i appreciate your help
  • 3 months later...
    Jmuck1
    Jmuck1
  • Who's Online   5 Members, 0 Anonymous, 709 Guests (See full list)
