Spark Plugs for 2003 Silverado 1500 HD CC
I would like to replace my spark plugs for the first time just as preventive maintenance on my 2003 Silverado 1500HD with 112K miles. Does anyone have a preference or recommendation of which spark plugs to use? Should I get the the GM brand from the dealership or online GM parts wholeseller?
Thank you!
AC Delco, NGK.
Purchase locally at aftermarket parts house or buy online
Consider replacing plug wires at the same time. If plug/wires have never been replaced, good chance of tearing a wire
+1. I'd avoid Bosch platinum's at all cost. I had 2 sets unload the platinum electrodes in the engine. I'm sure that was good for some cylinder scoring. :(
AC Delco, NGK.
Thank you. I will definitely replace the wires as well... great idea!
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
