2010 Chevy Silverado Z71 LT lift
I have racking my brain about the size lift kit I need for my truck. Originally I wanted 35" tires with a 6" suspension lift now everyone is telling me I'd be better of going with 33" tires and a leveling kit or a 4" suspension lift. Has anyone gone through this problem and if so what was the outcome? And if you can please send a pic so I can see for myself what it's gonna look like. Thanks everyone.
I did 7" because go big or go home lol I figured 4" was gonna be Barely noticeable and 7 turned out perfect. I went with full throttle and running 33s
Sent from your truck via Tapatalk
A 4" suspension lift like Rancho or BDS would be killer if you don't mind spending some $, or you could get about the same look for around $250-300 with a level and body lift. Either option would be good with a 33" tire IMO, just depends on what you want.
4" Rancho & 33's
Well I'm still in a similar situation, wanting to go with a higher kit ( i.e 6") with 33s, but after seeing a pic of your set-up, I think I made up my mind (2006 Chevy crew cab). Your truck looks awesome! I guess I tend to favor having more space between the tire and the fender than most other people.
If you want 6" and 35s now, you'll want 10" and 37s later. Never go smaller! Always go with what you really want, or even bigger. Otherwise you'll end up like me and countless others. Spending more money in the long run changing things around.
IMO a lifted truck should look lifted...not like an HD. Which is what 4" looks like...a leveled HD.
Been there too. Went with a 7" FTS lift that I could work up to 9-9.5" if I want. And that's what I did. 9".
Clears 35" with absolutely no issues.
Great thing about the 7" FTS is completely upgradable. Wanna run dual shocks up front? No problem. Wanna run their coilovers and go higher? No problem. Just call them up and tell them where you wanna go and wallah! Done.
Really good folks to deal with.
33" on a 6" lift looks like shit...been there done that...go for 6" lift and 35" tires..best combo imo
On stock wheels they might... Done right it looks good.
Here's mine with about 7" of lift on 33's, looked a little small IMO. Put 35's on about three days later though, but I'm from the South where we don't mind a little stuffage :lol:
35's
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
