Alignment issue
So I finally decided I wanted Goodyear duratracs I went with 285s but the alignment sheet came back and it said that my Camber was off and I did have substantial wear on my old set of tires that indicated that positive camber to be exact, but they said the adjuster cams were frozen? So how much does it cost to unfreeze the camber adjustment cams or replace them because I really don't want this new set of tires wearing like the old set and can I crank my torsion bars up and have the camber adjusted so the tires have a perfect camber after the front end is lifted up a bit? Also I believe my caster and toe were within spec but I'll get back on and post some
Numbers just to see if there within acceptable ranges.
Thanks,
-Kurt
You can go a little higher than stock and still get alignment within specs. They should be able to work the cams free. I have NEVER saw a set that was "froze"
