Anyone Running Soft 8s on a Stealth Grey Crew?
tyhuck
I know its fairly specfic question, but is anyone running Soft 8 steelies on a 06-07 Stealth Grey 1500 Crew Cab? I know there are a few guys with that truck in that color on here, but are any of them running a black steel Soft 8 wheel?
Im trying to figure out if I want to keep the black steel wheels on my new truck or put my new tires on the factory aluminum wheels.
I would keep the stock aluminum, those are the best stock GMT800 rims. personally not a fan of steelies on a newer truck.
its your truck! do what you feel looks the best!
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
