Top Tier Gasoline
'01LS1
In the 6.2L thread there are a few posts about ethanol or premium, performance & cost etc. going.
Was going to add this there, but it is kind of on its own.
So does anyone pay attention to the top tier gasoline way of thinking? Do the additives truly make a difference in how your vehicle runs?
http://www.toptiergas.com/retailers.html
Have only filled my truck up once since purchase & stopped at a local Mobil. They have 93, but it was significantly higher than local grocery store premium fuel. Just curious is all...
I stick with name brand fuel and that's about it. Try to avoid supporting Speedway since they supposedly are the ones responsible for the absurd prices/price swings in the Great Lakes region.
I run Chevron 80% of the time. Work credit card is with them and its a good quality
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I run anything that isn't ethanol, usually 89. I use the Lucas additive every half dozen tanks or so. The additive actually seems to help some.
I run gas mostly from my local Gulf station. That's the only place I buy gas in my area. Now if I'm out somewhere else I get from either Sunoco, Hess, or Shell in that order. I always run premium too.
I have a Chevron jones, and really do believe it's better gas. We took a 1500 mile round trip last year, during which time I couldn't always get Chevron. I could readily feel the lack of performance in the gas pedal and see it on the MPG readout.
I try to stick with the name brands. Around here (I have no clue how big they are) a chain called "Quick-N-Ez" has several stations. When I started working in the area and went from the BP/Amoco/Philips66, whatever to their gas my mileage went downhill bad. Like 4-6 MPG worse. Took me a few weeks before I realized what the change was. Went back to a different brand and with that one tank the mileage went back up 4 mpg! Not just one tank here, several tanks always ran poor mpg's through my vehicles from them. There has been a time or two over the last few years where they were convenient so I tried a tankful from them again. Same thing. So I stay away from them.
I have had about 50% of the fill-ups from another chain around here "Thornton's" do the same.
Of course the worst tank of gas I ever got was from a Shell. Must have had a lot of water in it. Truck would not even idle with it.
I would say around here (tankers come from the south, like Wood River/Alton IL area I think?) my safest bets are BP and Road Ranger.
You do not live very far away as those are my choices as well. I live about 10 miles SW of Springfield.
Have always tried to buy branded fuel. Years ago in high school they use to market the brands more & there was a Amoco & Shell across the street from one another. Always filled at the Amoco as it was still a service station with bays & convenience store was a afterthought(miss those). Anyway a friend of mine worked down the street at a bank & would watch the tanker go to both the Amoco & Shell stations. She killed my theory on Amoco fuel (marketing) being better than Shell.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
