Stainless Steel brake lines - A few ?'s
Do you remember the part number for the ones that you got? I would assume that they would be the same part number for a '12 and '08.
I installed them on my old '03 SS. They didnt have a listing for them when I was shopping.. thats why I had to call
  • 3 weeks later...
Can I get away with just bleeding the fronts since I'll just be replacing the front lines or should I rebleed the entire system?
I shouldn't have to bleed the ABS system since I'm introducing air after the ABS module.
Also, should I bother with replacing the rear flex lines at the axle?
I'm not even sure if the Russell kit comes with the lines for the rear or not.
both the kits for Sara (2001 Z28), and my 2004 Tahoe came with both front and rear hoses INCLUDING the line from the rear axle.
