You should be able to go into the vehicle settings in the infotainment center to access the wifi network. You should be able to change the password there.
Camera views are seen on the infotainment screen. Depends on the truck's technology package. You may just have the reverse camera view.
Did your truck come with an owner's manual? You can always look it up online at mygmc.com
The code has changed slightly so the steps for changing line 151 isn’t correct anymore. With every uodate from the developer, it changes so i will dm you.
i have the 8 speed auto in my 2018 I will probably never tow anything but a baby carriage with it sweet truck but I did not buy it for towing. 4x4 decent gas mileage, just learning how to drive with the 8 spd. it's cruise control on the freeway, and manual shift of the back roads.. the 8 spd is the soft spot.
on my 2000 silverado i could push the domelight over ride on and off twice and it killed the headlight. oddly enough, there is a little trick for everything.
