Trans lines and coolant tank part numbers
I need the part numbers to all 3 trans cooler lines. I hacked mine up when doing the cooler swap. i will be doing a cooling system overhaul on my truck and would like to change the trans lines as well. I am at 118k so I want to get to them before any leaking starts. I dont want to do a -6 AN unless I buy a new cooler that takes a -6 line.
Also how do I know if my coolant tank is first design or second? What is the difference?
Do you ever look stuff up before asking someone else for the #'s? :)
Rockauto has them. Easy to find yourself
Are you talking about the recovery tank? You should have the 1st design, with LC sensor
Yes I was looking on rock auto before I asked, my truck didnt come with the aux cooler so it is a little confusing to me. I want to make sure I buy the correct ones. These are the ones that I am guessing I need, but I want to be correct and not need to return anything.
As for the coolant tank, the years overlap for the 2 designs so I am lost on that one
I'm looking through files when I last ordered lines for some of our trucks
Any word on the coolant tank?
I think you got the AC numbers right. #'s on the right are Dorman. Rockauto does have all 3, you just need to pull up 624117 by the part #. If you go the Dorman route
15809058 624117
15773661 624116
15809053 624124
I've used the Dorman lines as well as the AC line. Both have held well
Tank. AC models - both numbers cross to the same Dorman # I'd buy the Dorman and save $10
AC Dorman
15808716 603102
    Markey
    Markey
  • Who's Online   3 Members, 1 Anonymous, 1,690 Guests (See full list)
