Trans cooler fitting size
I found a larger cooler I want, problem is that it has -6 AN fittings. What size are the cooler fittings going in to the trans and to the radiator? I see a lot of adapters for 1/4" NPT so is the the correct size?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
I was a hydraulic tech so I know the inch size of -x but I think the radiator and trans is NPT but not sure of that or the size. I know the cooler is -6 and I have connections at the local hydraulic supply so I can get the hose assemblies. I need to put together a pic for you so you can tell me if in theory I have the routing for hoses correct before I order them so the lengths are correct.
This is what the flushers are using. 3/8" NPT
OK so 3/ NPT to -6 AN makes the search easier
