Chris' 04 Sierra 1500 Fun Daily Build
Chris
No, I think it is the junkyard starter. But the camera was trying to auto focus as well
Ha could be that too. But that's about what mine sounded like with the dying 700A battery. With the 955A is almost instant.
  • Replies 699
The battery is coming up on the 3 year mark. My last optima lasted 3 years and 3 days.
Back at stock height and i am surprised the 275/55R20 doesnt rub
So I'm sitting here pricing out wheels and tires and saw this is what size you run. How well do you think this size nitro terra grap g2's and 20x9 (+18) will fit on my rig as it sits now? Found a wheel tire combo I love
Sent from my XT1080 using Tapatalk
I run a stock offset. +18 may rub a hair at full lock on the sway bar
That's not bad then. I know what I'm saving up for!
  • 2 months later...
I didn't get to look through your entire build.
What kind of mpg are you getting with your lq9 swap? City & hwy?
Is the engine stock with stock heads & cam?
What rear gear are you running & tire height?
What transmission?
Sorry for so many questions but I'm thinking of swapping in a stock lq4 long block to replace the 4.8 in mine for the power increase.
Both engines have around 200k miles on them.
I have 3.42 & 265/70/17 tires and I get 14 city & 16 hwy. I think this sux and the engine is gutless.
My truck is just a daily driver and I want torque and mpg.
Now I know a 6.0 may give worse mpg but a tune may take care of that to get back to the 4.8 mpg
Atleast I know the 6.0 will be very torquey and any hp on top is a bonus.
The 60e should survive as I don't race or dog the truck at all & I don't really tow with it.
I also have a set of stock gm 3.73 gears and a posi to swap in or keep the 3.42?
Do you have headers and did the make a difference in torque and mpg?
I have a complete donor truck that I'll pull the factory exhaust off as the pipes are bigger than the 4.8 exhaust
What transmission?
Stock LQ9 that is tuned. Has an intake, 6.0 head and mid pipes; 6.0 Corsa exhaust. I am on 275/55R20 Goodyear Eagle GT tires, i have the original 4L60E trans with a vette 2nd servo, and an open 3.42 rear gear. In town i get about 13 and on the open highway it is 17-18. If i do hold it at 55, it can hit 20 mpg
How hard was that servo to install? I've been thinking about adding one for the heck of it since its cheap
Hell i dont know. Probably on youtube. The shop that did the engine swap did that at the same time.
  • 4 weeks later...
Just put in an AVIC-8100NEX in my truck. Took 2 days to completely finish. Still have to do the fine tuning.
My new die grinder had some intimate time with my dash
It complains when i speed
Splash screen
Looks good! Who's it made by?
Pioneer
Which model?
I assume you used an adapter to connect your steering wheel controls. Which adapter did you choose: Axxess? PAC? Idatalink?
Which model?
Pioneer Avic-8100NEX. Axxess chime box and PAC SWI were reused from my AVH-P4400BH
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
