Chris' 04 Sierra 1500 Fun Daily Build
Chris
Had to take the LED bulbs out of my tail lights and rear turn signals. they were causing problems. Sylvania's advice is spend $240 on 12 load equalizers to have one per bulb. It was free to pull those bulbs out.
  • Replies 699
How were they affecting the tails? I've heard of them affecting the turn signals, but not the tails.
I hit left signal with headlights off, and all the parking and tail lights flash
Weird.
Weird.
I had a fridge in the bed and my aunt was following me to her office and called to tell me that every time i used a signal it looked like my hazards were coming on. The cluster and mirrors showed proper signals
Haha! Everything has to be difficult.
She called and told me when i was in front of a Sheriff
Ha! That makes it even better!
Would have been nice if she told me 20 minutes earlier before i got on the freeway
Did he pull you over?
No. He was likely able to see the signals in my mirrors.
Lucked out. Haha!
Hey, what all did you use and do to prep your dash bezel before paint?
Lucked out. Haha!
I think I used a 120 grit 3M sanding sponge, blew off with the compressor, wiped it off with acetone and a rag, masked with blue painters tape, and used the Rustoleum "Carbon Mist" metallic spray paint.
Okay. I'm considering doing something similar to mine.
Post 593, I said 120 grit. I like it being a black instead of gray.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
