Complete body swap
hey Guys im looking at Swapping the complete body From a 91 chevy C1500 305 5 speed to a 90 gmc c2500 350 3 speed auto and was wondering about cab wiring and compatibility is it just a matter of swapping ecm and steering columb do i need to transfer complete electrcal from one cab to other. Any input would be much apreciated.
Thank you Brennan
Steering column and ECM should do it. Unless your tired of shifting gears I would put the 5 speed behind it. Better fuel mileage longer engine life.
Thanks for the input Rev i went ahead and bought the chevy so im comiited now i thought about using 5 speed will the clutch housing Ect. be a direct bolt up to my 350?
Same bolt pattern on housing and flywheel. If its 3/4 ton prob has knockout in floor board for gearshift.
The yoke on drive shaft may may be different on 3/4 ton. That should be your only worry. I'm just not sure about that. But a quick measure of u-joints will tell you. The 350 trams yoke may not slide in 5 speed. But spline count & measurement will take care of that also. Length of shaft may come into play but I would def try to stay with 5 speed.
