Flushing trans
What is best way to change auto trans. Fluid / I have a 06 2500Hr GMC with Duramax and allison auto.Thanks
go buy two gallons of oil from your gm dealer. drain oil in pan. add two gallons of oil back into tranny through dipstick. that is what allison recommends.
A reputible mechanic or dealer will have the right flushing machine for it. the Allison is safe to flush if done right and flushing will benifit the tranny more then just doing a fluid exchange.
At some point 2006 Allison changed seals to be Dex-VI compatible. Before the cutover, Dex-VI may cause the seals to eventually start leaking. GM says there's no problem and will give you Dex-VI if you go to a dealer. Allison says there is a problem and you should use a Dex-III fluid (like Mobil 1 Synthetic ATF that says "for 2005 GM or older" in small print on the back, or check the Mobil wesite, OR better yet, a TES-295 ATF like Transynd or Mobil Delvac ATF but both are only found at semi truck dealers). You can trust Allison or you can trust GM, that's your decision.
You'll have to search the 'net for the cutover serial number since you have an '06, and then find your serial number to see if you're Dex-VI safe.
Allison recommends drain/fill method. Some passive flush systems are ok to use, but you'd have to find out what machine a shop uses and research that to be sure. A power flush will likely cause big problems later. Again, Allison recommends drain/fill and change the external filter (remembering the magnet).
dealers dont have a flush machine unless they want to wallet flush their customers ,,,,,,ive never seen one in any of the dealers i worked at ...
they have a cooler flush machine that is an essential tool they have to buy and use during transmission rebuild/replacement
no code from machine on warranty w.o = claim denied if audited
Alot of dealers have flush machines now supplied by aftermarket vendors.
I would strongly suggest taking your truck to a dealership or reputible trans shop for a flush & spin on filter. The 2 gals of fluid mentioned above will only get the fluid on the converter and the pan. The dealer I used to work at used 4 gal minium on a trans flush.
    • A little late to this. I am going to order a 2027 as soon as the order banks open. It'll be a 3.0l again. This time in a Yukon.
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
