Just an update, I bought a one VIN subscription to sps2, installed the PCM from the 2007 donor vehicle and programmed it. It started right up, and seems to run more normally now (It doesn't die as soon as you start it, it just starts and runs every time, no more misfires too), however, the MAF is still showing the same strange readings.
Hey everyone,
For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.
The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.
A few details:
50" curved PRO light bar
Fits 2022–2026 GMC Hummer EV
Spot + driving beam pattern
TIR optics
White main beam
Amber DRL backglow
Approximately 15,410 measured lumens through the lens
Mounts to factory accessory locations
No cutting or drilling required
Wiring runs down the A-pillar toward the AUX connections
Designed to minimize wind noise
Lifetime warranty
Off-road use only
The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup.
For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".
ONE MB??? That's Windows 95 ******, lol!!
