Leveling The Front End
I want to level the frond end of my truck up so it will set level with the back. I know the backs supposed to set higher so it levels out when you put a load in the truck bed or towing, but I'm 16 and I don't haul but only on occasion and never tow. I don't want to cause any premature wear or risk breaking any tie rods or ball joints or anything like that. I don't want to do a full suspension lift and have to upgrade to bigger tires and lose what fuel economy I get. I have a 1998 GMC Sierra 1500 with the z71. It's a single cab short bed. Do y'all recommend any kits or any other suggestions on how to make it set level? Thanks in advance.
I put the 2'' Rough Country on the front of my 07 Silverado, leveled it out nice and no problem. Get it re aligned after you do it. Just my 2 cents
The rough country lift bruceduece has won't work on your truck as he has coil springs and you have torsion bars. Easiest thing to do is crank the torsion bars. But......this will poorly effect the ride and will most likely cause premature wear on front end steering and suspension parts. I had a 1997 1500 Chevy, I cranked the t bars and put 2" lift blocks in the back with LT285's....looked great.
He has a 98 so no blocks under the struts. All you need to do is crank the torsion bars at the adjuster, go about 4 even turns on both sides that will give you about 2" and JACK THE FRONT WHEELS OFF THE GROUND FIRST before turning the bolts this will relieve some of the tension off the adjusting bolts and is a good idea to spray the bolts and threads down with some WD-40 a few hours before you do it since its a 98 and the threads are most likely rusted.
Yes the ride will be stiffer some and since its a 98 the "T" bars are most likely tired and dropped some over the years.
U don't need keys. On your body style the stock keys will be more than enough
Sent from my SGH-I927 using Tapatalk 2
Also, since your keys are stock and about 15 years old your bars could be corroded in the keys pretty good and really hard to separate. 4 complete turns of the adjustment bolts should be a good starting point to level the front of your truck. Like said before, use a jack to take the weight off of the front wheels when adjusting. When done take it for a ride and see where the height ends up. When you like the height, take it and get an alignment.
I heard cranking the T-Bar puts a lot of stress on your front end? And makes the front tires point inward? Has anyone had any problems with cranking t bars? Ball joints? Tie rods? CV Axles?
1st the is NO difference between "cranking" and "leveling kits" other than leveling kits can be cranked farther. Its the same stress no matter what. An alignment will fix the tilted tires. And as with any modification yes there is the potential for faster wear on your parts
Thank you very much!
I've been wanting to do this for quite sometime now and been afraid due to breaking something.
So, I began looking into leveling kits, suspension lifts, add-a-leafs, yada yada, and I stumbled across the Tuff Country 2 inch suspension for 185 bucks which isn't too shabby.. I'm currently running 265/75/16's. Do you guys think I would need to upsize tires if I installed the lift? I don't want my truck to look like it's driving around on little black knobby rings.. any help?
Why are you totally ignoring the advice you've already been given? Try cranking up your existing T-bars first. You shouldn't go over 2-2.5 inches or you're going to be causing issues . A lift kit has torsion bar adjusting keys that crank your torsion bars even further; which would cause more problems. Listen to the guys that have already done this, there's a lot to be learned.
Crank your stock keys bud. The 90s models normally don't need a "2 inch lift". The stock keys will do the same thing free. A lot of us have done this. Don't waste your money just yet
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
