hard start when weather gets hot
stahlhelm35
I have a 2002 Sierra 1500 sle with the 5.3l. I experience this problem every year, when the outside temp gets hot, summer time. In the winter, its fine. What it does is not start like it normally does. Sometimes it takes three or four times of cranking it over, to get it to start. I know its fuel injected but pumping the throttle a few times seems to help. I cant figure why it does this. If it was a fuel pump issue, wouldnt it do it throught the year and not just the summer?
Jeb
I am not really one to give advise because I don't know much . All I can think of is the basics air and fuel . In the summer the air is thinner maybe its a air thing. Some guy on here is just going to tell you to get it scanned and take it in to the dealer seems to be almost a common response now. There is a other guy that does give out pretty good advice on what might be the problem . Maybe he will chirp in . I am assuming since your on here like alot of us you dont have the money to just take it to GM and get them to scan and work on it .
The first smart thing to do is to scan it for codes with a good scanner. Post any codes
Check fuel pump pressure. Key on, engine off. Post reading.
Check fuel pump regulator for presence of fuel at the vacuum line
If its one or all of the things you listed, wouldn't it do it when the weather is hot or cold outside? Or would the heat be affect the fuel more?
Jeb
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
