What is this going to cost.....
ram1067
I have a bad front wheel bearing or hub on my 06 silverodo CC 4x4
Can I replace the just bearing or will I have to replace the hub also? What is this going to cost?
Thanks.
It's all one piece. Remove rim, have someone hold the brakes while you undo the CV shaft nut. Then undo the 2 bolts holding on the brake caliper and put it on top of the UCA, then pull off the brake rotor. Undo the 3 bolts holding on the hub assembly. You might have to tap the CV shaft gently to get it free.
I think I paid $120 each for my hub assemblies. If your brakes are getting worn out, you may as well do them at the same time you change the hub. I did brakes and bearings on each side just to have it all done.
hey thanks for the input.......going to the dealership today :eek:
also going to price out a new unit while im there......they might just get to keep the 06 :fingersx:
Dealership? Well, you'd better add at least $500 to that ....
O'reilly's had all of my parts in stock....and they were WAY cheaper than the dealer. Why are you going to the dealer for parts?
great.....just dont have the time to do it myself. need a quick turn around so ill have to pay..... :banghead: or might pull the trigger on a new unit! :thumbs:
Try local mechanic shops also. I know they have done plenty of them before, common problem and easy fix. Might be cheaper than the dealer. Besides, you have a great looking truck there, hate to see it go!
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,073 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
