Wiring questions 2013 Sierra
I have a 2013 SLT that I added a stock navigation unit and have it programmed to the truck. Everything works but I need to get video feed into it from the backup camera? The truck did have factory backup camera that went thru the rearview mirror but I need to get it so it comes over the nav unit screen? Can someone tell me how too do it? Do I need to keep the original big mirror and run wires down from that or can I use a small mirror.
Also I added a factory rear sliding window and I put in a factory cab harness that connects into it but I still need to get power up to the switch on the overhead console? Can someone tell me how too do that too?
Thanks for the help, Jonathan 319-325-8791
Common question, I'm working with a similar issue, is the Nav a 2013 or earlier? if you pull it the 2013 will have 3 main plugins, a really big one X1, a smaller one X3 which is what I need so that I can add rear audio inputs and a similar sized one X4 which is white and is used for the backup camera, there's another post on this site regarding that plus an extremely good blog on the subject
http://xenawise.blogspot.ca/2013/03/retrofitting-2012-2013-hard-disk-drive.html
I suspect although I'm by no means an expert that you will need a partial harness to go from the Nav up into the headliner since you clearly have the portion running to the rear of the truck, there is also a post on this site
http://www.silveradosierra.com/mobile-electronics/2013-sierra-navigation-t50025-20.html?hilit=xenawise
I have a 2013 SLT that I added a stock navigation unit and have it programmed to the truck. Everything works but I need to get video feed into it from the backup camera? The truck did have factory backup camera that went thru the rearview mirror but I need to get it so it comes over the nav unit screen? Can someone tell me how too do it? Do I need to keep the original big mirror and run wires down from that or can I use a small mirror. Also I added a factory rear sliding window and I put in a factory cab harness that connects into it but I still need to get power up to the switch on the overhead console? Can someone tell me how too do that too?Thanks for the help, Jonathan 319-325-8791
I contacted Dan at United Radio this morning and told him what I needed, he made me up a custom harness to fit my HDD nav to give me an additional audio and video input, charged me $80
Sent from my iPad using Tapatalk - now Free
