OnStar Remote App.
My Onstar app no longer works after the sept 11 update was applied. Won't take my user I'd password. Only breaks after that update is installed. If I delete app and reinstall it installs the older version and works. I am running ios 7 GM.
They fixed it today with a new version available in the App Store. Works like it should again.
  • Replies 36
Apparantly on the 2014's if you download the app during your free trial of OnStar, you can keep using the remote unlock/start features once your trial expires. You get it for 5 years!
I just bought a 2013 will this be true for it too? How can I check it?
Sent from my Galaxy Nexus using Tapatalk 4
Electricchicken7 -
Unfortunately, only OnStar equipped 2014 GM vehicles are eligible to use the RemoteLink Key Fob functions. 2013 and earlier vehicles are not compatible with this functionality.
The 2014's do come with 5 years free; simply download the app, accept the End User License Agreement and use the app at least once during your trial period (or consecutive paid OnStar subscription) and the service will be available to you for up to five years. I hope this helps. Let me know if you have any additional questions.
- Sara, OnStar Advisor
Social Media Team
Electricchicken7 -
Social Media Team
Are you sure about this? My 2013 CTS uses the Onstar Remote app and all works just fine with it. Not sure about the 5 year free part, I think that is new for 2014's, but the app should work.
Mike
Originally Posted by blckthree
Electricchicken7 -
Â
Â
The 2014's do come with 5 years free; simply download the app, accept the End User License Agreement and use the app at least once during your trial period (or consecutive paid OnStar subscription) and the service will be available to you for up to five years. I hope this helps. Let me know if you have any additional questions.Â
Â
Social Media Team
Â
Â
Mike
I apologize for being unclear, Mike - The "5 years free" functionality is what I was referring to when I said "key fob functions," specifically the door lock/unlock and remote start features. Those functions will continue to work on 2014 vehicles even without an OnStar subscription.
The full RemoteLink application will function with 2011 vehicles and newer, as you indicated, but will require an active OnStar subscription to be able to use. I hope that clarifies things! Let me know if there you have any more questions.
~ Sara, OnStar Advisor
Social Media Team
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
