Is 5w-20 bad???
Well, after waiting forever at the Wal-Mart to get my hunting liscence, and leaving a quart of oil and a bottle of fuel system cleaner at the register, I got home, drained the oil, and pulled the filter before I realized that I grabbed a jug of 5w-20 instead of 5w-30. I had no choice but to fill her up with the 5w-20. I know in my old 96 2500 the manual specified NOT to use 5w-20. Are the LS based engines ok to run on the 5w-20, or should I change it out ASAP? I will be honest, between the kids, making dinner, and trying to clean up after some remodeling, I barely had time to do the change, much less read the manual. My apologies. But, now that I have a moment, its easier to ask here than to go back outside and check. LOL!
Well, its kinda too late. Im 20 miles from anywhere I can buy oil, I had already drained the oil, and I have to get to work tomorrow. Had no choice but to put it in. My question is, will it hurt anything?
The oil actually was Mobil 1 5w-20 High Mileage. I normally run Mobil 1 5w-30 if that makes any difference.
I would change it when you get the free time. Keep an eye on it and see if anything changes eith the truck
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
I would.
Personally, I would change just the oil when you get the chance. The filter is new and it wont really care what weight oil is passing through it. You could even catch the barely used 5w-20 in a clean container and re-use it in something else that takes 5w-20. A few hundred miles on filtered oil is no big deal, same for the filter. Having a few hundred miles of a slightly thinner oil running through it wont matter at all.
To avoid a problem like this again, just make a promise to yourself that you will not do any automotive work in a rush. Being in a rush will greatly increase your chances of a mistake or accident. Mistakes can be costly and accidents can injure or kill you or someone else. Either make plenty of time for your automotive work so you can really pay attention or do not do it at all.
That is the main reason I will never be a mechanic for a living. The Pro wrenches normally get paid by the job so the faster they work, the more money they make. Rushing leads to poor workmanship, more mistakes, and less memory retention of learned techniques and skills. The fact that I take my time, pay attention to all the details, do excellent work and learn from every job I do would not be appreciated if I was doing the work on somone else's clock. I know I am getting a little off topic here.... Sorry. lol
It will not hurt a thing. I ran 5w-20 in my 2002 5.3 with no issues. Matter of fact the used oil analysis, UOA, showed no increase in wear over running a 5w-30. I ran the 5w-20 for 6k mile oil change intervals and did those oil changes to see how things would go for I think 3 oil changes. Like I said, no issues at all. I was kind of hoping to see an increase in mpg, even if it was 1mpg but I didn't.
From what Ive seen on other sources, the concern is under load or under high RPM cycles the oil doesn't provide adequate film thickness for key parts like the crank shaft and bearings. Im not a mechanic, or an oil expert, but would it make sense that if the oil pressure stays up around normal levels I am adequately protected, or will oil that's too thin make no difference in pressure once circulated?
My main concern is the fact that I am running in temps of 90-98 deg F. Mostly its highway driving on small rolling hills, but sometimes I am towing about 2000 lbs. Will this oil hold up to that?
On a side note, I also noticed a large amount of grey goop on the magnetic end of my drain plug, and I would assume this to be metal from the inside of my engine since it was magnetic. I have no idea how the previous owner of this truck maintained it, so I want to make sure I take care of it. It runs great and has lots of power, and no noises or leaks, but I don't know what the inside of that engine looks like. I just don't want to screw it up because I am not sure how long I will have to keep this one. Ideally, I will trade it in on a new 2500 in 2 years when my wife pays off the Tahoe, but who knows what will happen between now and then.
Again, I don't want to screw anything up, but with money as tight as it is right now, Im not all about throwing another $45 away if I don't need to. I realize it might be cheap insurance to replace it, but again, $45 is $45. Know what I mean?
I'd change it when you get a chance. If you're worried about your engine get an oil analysis done next oil change, they'll catch anything that is out of order.
http://www.blackstone-labs.com/
That's who does mine. The reports are pretty thorough, here's my last one. I'm planning on sending another sample my next oil change. $20.
DANNY: Things look great in this first report for your Silverado. Our universal averages for the GM 5.3L V-8
are based on ~5,800 miles of oil use, and you can see that your metals are reading at or below those
averages on a similar oil run. That's a good indication that there are no mechanical issues or other obvious
problems developing, at least as far as we can see. No moisture, dirt, or fuel was detected, and the low level
of insolubles points to good oil filtration. All in all, things are looking great for this engine as it crosses the
100,000-mile mark. Try 7,500 miles next oil. Nice!
In addition to the written report, they'll include a chart showing all the technical information about what was in the oil (fuel, water, metals), as well as flash point and other properties.
5w20 won't kill your motor especially at the temp your at. If it was in the low 30s and below I would say change it, but you will be fine.
Well, I figured another $45 was cheap enough insurance, so I just replaced it today. Ide seen too many mixed answers on this topic all over the inter-web, so I just went ahead and drained it and put new 5w-30 in it. I couldn't save the oil because my oil drain pan is too dirty and grimy to keep anything clean. If nothing else, I now have about 12 qts of quenching oil for my handmade knives.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
