Installed Addco swaybar on 2010 Silverado
I tow a pretty heavy travel trailer (about 7,500 pounds, about 1,000 pound tongue weight) with my Silverado 1500 Extended Cab Z-71 (6.2L, 3.42). In pursuit of a better towing experience, I installed the Addco swaybar recently. I had previously done some 1,500 pound overleaf helper springs to keep the truck level (I also have the 2" Rough Country leveling kit in the front). I haven't towed yet because life keeps getting in the way...
All I can say at this point is "dang!" I really didn't expect my ride to be significantly compromised when empty, but you can definitely tell that it is much rougher. In fact, I'm even considering removing the sway bar! I actually don't tow that much, and I could put it back on when I'd be talking a longer trip.
Anyone else have experience with this?
Thanks,
scott
Are you using a weight distributing hitch? Properly adjusted you should be the same as unloaded as far as level goes and unaffected when not towing. Some of these setups also have built in anti sway features.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Yes. I have the Hensley Arrow hitch system, which completely eliminates sway and also distributes the weight.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
