Switches/Cutting Question
Hey guys, I have a single cab 05 Silverado and I'm going to be adding some switches for some small mods. I was just wondering how I should go about installing my switches... I was thinking about putting one underneath my cargo light switch (if I can get in there, haven't pulled the switch out yet) or in between the stereo and steering wheel.
I also have never cut up a dashboard or plastic so any tips or know-how on how to cut the plastic, make the holes to fit a 12mm round rocker switch, and anything else that might help make this easier for me. Thanks!
- John
You need to invest in a dremel if you don't want it to look like a beaver did it.
Sent from my HTC One S using Tapatalk 4
You need to invest in a dremel if you don't want it to look like a beaver did it. Sent from my HTC One S using Tapatalk 4
Already have a dremel. Any certain bit I should use for plastic?
Just use a drill. make a test hole in some plywood or something and select the correct bit.
Thanks for the input. :P
Drill slow, so you do t melt the plastic and you will do fine
Sent from my SCH-I535 using Tapatalk now Free
Simple questions get simple answers.
    overspeed
    overspeed
  • Who's Online   5 Members, 0 Anonymous, 1,142 Guests (See full list)
