Pacer smoked cab lights 07-13 style BNIB
New in box LED Pacer smoked cab lights. These are the three piece OE style light pattern lights.
I have installed a set of these before so any questions please ask.
$110. Paypal accepted.
pics?
Pics added, I used a 9v batt to show the LED's on the center cluster. Wired into your truck, they will be a bit brighter.
FYI: These are "plug and play" on the RHS kick panel for the GMT900 1500's if you have a "power" truck (power windows/mirrors). W/T's need to be "hard wired".
FYI: These wire to the RHS kick panel for the GMT900 1500's (and presumably the 2500 is the same way) if you have a "power" truck (power windows/mirrors). W/T's need to be "hard wired". there is a dedicated Park Signal Supply Voltage (Second Pin from the left at the top)
Bump for a correction. After a little research I had to correct my statement above which applies to all trim levels.
Still available. $100 SHIPPED
