Re-program after changing tire size?
danny68327
I have a 2014 1500 Silverado that came with 265/65/R18 (31.6") tires. I would like to change to either a 275/65R18 (32.2") or preferably a 285/65R18 (33") tire. Will I need to re-program my truck? If, so will chevy do that for me? If I don't, will it cause any damage? Thanks for your help
Most aftermarket performance programmers have that parameter in the unit. If you don't get it right, the speedo will be off, and your dash will light up like a Christmas tree with check engine & ABS lights ... and you'll lose ABS function. Ask me how I know that one!! :D
Gm will not reprogram. You have to go aftermarket
Also look at a 275/70/18.i am running that size on my 2010
Ryan
Thanks. What was your original tire size, and how much bigger did you go?
Gm will not reprogram. You have to go aftermarket Also look at a 275/70/18.i am running that size on my 2010 Ryan
I would like to go 275/70/18 but i'm hesitant to use such a tall tire. I tow a trailer and I'm afraid it will have a negative affect on on the gear ratio (I have a 342).
I went to 275/65/18 from 265s and it is off by like 1 MPH at 80. Below that the speedo matches GPS.
    timcpeters
    timcpeters
  • Who's Online   1 Member, 0 Anonymous, 1,193 Guests (See full list)
