Low Cold Engine Oil Pressure
Hey guys,
Hopefully someone can help me shed some light on this. It may be an issue, it may not be, but I would like to get some input.
I have a 2006 Silverado 1500, 5.3 liter. Just over 104,000 miles on the clock. I run Royal Purple Oil, K and N filters. I change the filter and top off every 3,000 and do a full engine oil change every 10,000 miles. Lately, on cold mornings I have noticed my cold oil pressure doesn't seem go as high on initial startup as some other trucks. Similar year model trucks running dino oil get about 50-55 lbs cold oil pressure on startup and stay that way for a while before stabilizing.
We have been having colder mornings (30-50 degrees here in good ole Louisiana). My truck lately has been getting about 40 lbs on cold startup lately, and quickly leveling out to 35 lbs cold idle where it stays rock solid. When driving cold, I may get up to 40-42 lbs, but typically not higher. Once the oil/engine warms up, I see it fluctuate from 35 lbs hot idle to 50 lbs hot running. I get 60-75 WOT.
I can't imagine (though it is possible) that I have a sludged up motor, but are there any other reasons why I might notice this? I'm all ears, and it may not be a problem but I want to make sure I'm not having any issues popping up. I know it is within the year model that can have the castech head issue, and I have a 706 casting, but to the best of my knowledge, I've never lost any coolant. I've never added any and it stays constant on the tank, though slightly lower on colder mornings.
Thanks!
I understand that your that the oil is expensive, so I see you reasoning for your 3000-10000 oil change interval procedures. However from my past experiences for working at a dealership, the longer oil change intervals will not help you in the long run. Oil trap contaminates, and a single oil molecule can pass through your motor up to seven times before going through your oil filter. But on the flip side, the 02 Avalanche that has a 5.3 which is still in the family had Speedee mobil1 oil changes every 10-12k from new until it had roughly 270k on the clock two years ago, and it is still running strong. If your just going to throw parts at it. The oil pressure sender would be a start, and an new oil pump would be a more of a worst case scenario from there. Good luck.
I respectfully disagree with this statement, I have been using pure synthetic oil in Sara (2001 Z28, 37k original miles) changing the oil every 2 years (adding when necessary), and have no ill effects from doing this.
I owned a 2004 Chevrolet Tahoe (4.8L) with 117k original miles and used high grade synthetic oil changed every 10k, and had no ill effects from doing this.
The dealer uses a synthetic blend oil, that I would not use in my lawn mower.
JMHO
Hey guys,
Thanks!
Truthfully, I think it is the colder weather contracting some seals and the oil itself thus making this issue a bit more noticeable. I have virtually the same truck as you and am in Austin with the same results. You didnt mention which oil weight you were running but I figure either 5W-30 or 10W-30.
As a simple, free test, (if you have remote start), get upwind of your tailpipe, start it up and see what happens over 5-10 minutes. Also notice the smell and see if any sweet smell comes out. If there is no smell (besides exhaust) and no burning of any kind, I would say that you are fine.
JMHO
For this time I guess we'll have to agree on that we disagree. There are reason's why GM has current Service Bulletin updates for shortening their vehilces' DIC oil change interval. I wasn't trying to bash anyone who goes extended oil changes, but temperate and driving habits greatly affect when you should change your oil. Once again look at our 02 Avalanche that has a lot of miles on that 5.3l, and had extended oil change intervals.
GM oil is good oil, it has to be in order to back up warranty for things like extended oil changes. However, some dealers tend to not use GM oil programs because it cost too much, and instead use an economic oil from an outside vendor that meets the GM spec. One of the reasons other than keeping low running costs, GM sends out mailer coupons for oil change specials and what ever. Now if the oil change is at a price that is much lower than the total cost of GM oil and filter before any labor the dealer has to accept the use of the coupon the customer presents and find ways not to take a major lost.
Back to Burnthefurniture, at least you have been using a synthetic oil. You'd be amazed to see how some of the newer pickups' oil pressure gauges moves due to temp, and operating at WOT>cruising>stopped in drive>parked. Now you'd know if you had a sludge up motor; they just don't run well, the motor would shake and makes all sorts of noise most of the time, and during oil and filter changes you'd see the sludge. Plus synthetic oil doesn't break down like conventional, its finer molecules so they tend to actually clean the motor and remove sludge build ups. What ever you do, do not do an "Engine Flush" of any sorts. I hope that this helps.
You have enough pressure IMO. My 2006 runs near that, and it's always ran great. It sees colder temps than yours too.
If you're worried about it, send in an oil analysis. They can tell you exactly what's in your oil.
My 05 stays starts at around 35-40 gets up to about 60 on the interstate here in Colorado. But I gotta ask are y'all high? Oil changes every two years? I think 10000 is pushing it. I run amsoil in my bike and change every 5000, I run castrol full synthetic in both my trucks with Fran tough guards and change every 5000.
K&n oil filters are crap there have studies to show they don't catch as many contaminants as other brands to include factory ones.
Your oil pressure is fine but if you think you have lost some, check for leaks around the heads and the pan. Also do a compression test this will let you see if your rings and/or cylinders are wore and could be burning a slight amount if oil.
Thanks for the replies. A couple more details I didn't mention the other day. In addition to the RP and K and N filter, I run a filter mag magnet in addition to the little magnet that is stock on the drain plug. The motor is and always has been absolutely dead silent. Not once, even in the coldest temperatures that Louisiana can muster have I ever had a tick or lifter tap on startup. The truck runs great, and very strong, so I wanted to post mainly for the sake of being proactive.
The oil is expensive, yes, but so is a new motor. The oil price or filter price was never my motivation behind the change interval. I bought 3 cases of 5w30 RP a few years ago and change according to my interval, which is roughly based on oil analysis. A close friend with identical truck and very similar driving situations who uses the same oil, filter, magnet combination has tested his oil after every change for over 100,000 miles and every time he sent it in, they told him he could run it longer...up to over 25,000 miles. Now, that seems ridiculous to me and while it is not my truck that testing was done on, I would never trust running the same oil for that long, just from a standpoint of contaminants as mentioned. However with mobil 1 and some others touting extended changes up to 15,000 on a single OCI and single oil filter, I feel that my interval was a pretty good medium between all of the above. Nothing at all scientific about it, so don't flame me. Just the motor runs great, very strong, and dead silent.
Austin and BR have very similar climates, so I am appreciative to hear that there are others with similar experiences. I run a 5w-30.
I've run synthetic oil ever since about 36,000 miles. Before that, I was getting oil changes at the dealership based on the OCI while they were free. It was really just too time consuming to wait 2 hours for an oil change for free when I can do it in 20 minutes at home. Since then I have run synthetic. For what it is worth, I changed my oil yesterday, just to test a few things. I drove about 15 miles and changed it as soon as I got home, to flush out any contaminates and sludge while still in suspension. My RP stash had run out on the last OCI so I bought Mobil 1, just to change things up. While the drain plug was out, I had a piece of wire which I stuck into the bottom of the pan to see what I could "feel" in the way of sludge or contaminates, if there were any. This was not a scientific test at all, and it was based on my assumption that such would fall to the sump of the pan. The pan was absolutely clean, no resistance in wiggling side to side, and nothing but clear oil came out. I also removed the oil filler neck and looked into the top end to see what I could see with a flash light. It, too was absolutely spotless, nothing but a slight oil discoloration on the metal as you would see on any motor.
I mentioned above that I changed to Mobil1 with my change yesterday just for grins and giggles. Across the board, hot or cold, I am seeing about 5 psi higher in every regard. I am considering this could be a difference in flow characteristics of the two oils. RP people claim Mobil 1 is not on the same level of synthetics as Amsoil, RP, Redline, etc., but nevertheless, its a great oil and just a possible different formula could cause this result.
Based on my previous responses, I am much less worried about the pressure as I was previously, however I would be interested to see what your source about the k and n filters is. I am not looking to contest you, I have always wanted to have the best filter for filtration and flow and if its not K and N, would love to see a side by side comparison of what is best.
Ill see what I can dig up for ya. However, I learned this thru a buddy that sent his oil in for analysis from his CBR 1000. He tried many brands of filters each for one month all using amsoil. He said the k&n oil filter was the worst outta the five he tested. So just take what I said for what you want. I just know that I changed the filter the next day on my old vw gti and come the next oil change my catch can held a lighter color inside it.
That filter mag is probably one of the best ideas I have heard in a while so props for that.
    FiLo
    FiLo
  • Who's Online   6 Members, 0 Anonymous, 654 Guests (See full list)
    • sorry to bump an old thread, im a bit clueless with this stuff, would these fit a 2019+ Silverado? https://wiperpro.com.au/products/chevrolet-silverado-wiper-blades mainly wondering if the beam shape stays planted at highway speed, thats what seems to let the factory ones down imo
    • I have a 2018 Silverado Custom with 156k on the odometer. In the last month I've replaced the plugs, wires and the driver side engine mount. My wife just returned from a trip of about 1500 miles and told me the brakes are making a grinding noise when applied. I drove it and looked it over and this is what I found with the driver's side rear rotor.   I'm going to order new pads and check about having the rotor resurfaced. Hopefully this is easier than the last 2 jobs.   Peace
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
