I Upgraded My Magnuson Radix Heat Exchanger
I have a 2005 Silverado with a Magnuson inter-cooled Radix 112. I have been trying heat exchanger upgrades and contacted MercRacing with my needs and he delivered with a larger triple pass unit that is well built and very versatile to adapt.
The unit has a high count fin core for excellent heat dissipation and coated end tanks and headers for durability and long life.
Mine is a first run non-vehicle specific prototype that was configured with four threaded mounting bosses on each side with a downward facing port on one end and a side facing port on the other. With this setup I was free to flip or rotate the heat exchanger in any orientation that suited my installation. The only preference MercRacing suggested was to flow inward to which ever port I had orientated on the bottom.
Another thing I like is I have room under it behind my bumper to mount the Radix heat exchanger in line with it if I want, and I probably will.
The installation adaptation was very easy only requiring me to fabricate two small plates to get the mounting points onto the Magnuson Radix rubber mounts. I used over sized nuts over the plate bolts and top bracket bolt to adjust the spacing outward to maintain the trans cooler clearance.
My test results:
Weather Conditions were within 3°F on each test. Humidity was high and in overcast conditions on both days.
Each run was made on following days so the conditions of a fresh start up from sitting over night and matching warm-up drives to the WOT run area I use.
• When doing matching WOT runs up to 115mph both HX’s matched the raised IAT increases at the end of the run of 30°F.
• The MercRacing HX recovered in 1 minute. The Radix HX took 1min 40 sec to recover. Almost a minute advantage. On each run I would let off in the same way and hit the cruise control @ 65mph and monitor the time and temps.
• At cruise well after recovering from a WOT the MercRacing HX IAT's fluctuated 5°F to 10°F cooler than the Radix HX, according to if one is going uphill or cracking the throttle plate a little more. It was also noticeably faster to recover from playing around.
• When idling in the driveway after returning from a run and letting it sit for 15 minutes with the fans doing their cycling the IAT temps were 5°F lower than the Radix = 115°F vs, MercRacing = 110°F. This is in heat soaked conditions.
• At the same time I placed a temp probe in my return reservoir tank and the MercRacing HX held 8°F cooler than the Radix. This idling test thing is a test or curiosity I have. The throttle plate is closed and the blower is bypassing the screws I know. I guess it’s a way of testing the cooling of the intercooler when no air is flowing through it?
The pump flow returning into the reservoir looked to be unchanged with a strong flow.
I am happy with the improved cruise temps and faster recovery capabilities and the option to add my Radix in the line instead of trashing it or standing it in .
annotatedmercadoscroller_zps5e1ce9d9.jpg~original
If you did you wold not regret it. Back in 2005 I had a Kawasaki Prairie 650 4Wheeler that I was not using. I sold it for $5000.00 and that covered a turnkey Radix install by a Radix experienced installer. Then came the other stuff. I could have done it but a ASE certified installer is required for warranty reasons, and I did not want to venture in to the new territory.
I have a prairie 360, too bad we didn't even get it for that much lol. Actually just did a carb rebuild and some other stuff getting it ready for winter
Sent from the side of the road...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
