HID Fog Light Replacement?
Hi Everyone,
Quick question I haven't seen in my browsing. If its been answered already I apologize.
I have seen the posts and issues with HID replacement in the factory headlights but I haven't seen anyone talk about the fog lights regarding HIDS other than non performance enhancing LED bulb replacement. Are there any known problems with function/performance when replacing the stock fog lamps with a HID set up? if not, what kits have people had good luck with?
Thanks!
They will make a night and day difference...DO IT!! :thumbs:
Try DDM, as most members have been installing. They have a great warranty too. Keep in mind, stick with 35W as 55W may cause problems with heat, melting/wiring issues. You will need a H16/5202/9009 bulb size.
  • 11 months later...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
