94 sierra lift keys?
Should i get lift keys or just use stock keys? It has a 3 in bl with 33s. And how do you know how many turns youve did and dont lift one side more than the other i just wanna get about 1.5-2 inches of lift to level it out?
You could go either way. Me personally I put the reindexed keys. As far as adjustment you just adjust both sids equally & then if a little off from side to side, adjust individually. Also start by adjusting then go for a ride to settle the suspension before readjusting. Make sure jack up the front with wheels hanging so the keys are unloaded.
Also make sure the lower control arm still has some downward space for movement. If you crank them till they hit the stops your ride quality will be interesting.
