2014+ Door Handle Removal
I've seen a lot of people lately looking to remove the handles and swap for either color-matched or chrome. The door handles remove very easily without removing the door panels and take about 30 mins to swap out. They swap similar to a lot of newer Chevrolet models such as the Equinox and Camaro with some slight differences.
Here is a video of the removal of the handle on an equinox, watch the video and I will explain the 1 extra step (step 5) that is not shown here -
1 - Open door.
2 - Remove black plastic cap inside door jam.
3 - **IMPORTANT** back out the torx bolt located behind the black cap only enough to remove the handle cap. I loosened just enough until the cap was loose and was able to be pulled away. IF you back the bolt out (on the rears for sure) there is a nut that will fall into the door and you will need to remove the panel to get it out.
4 - Once you have the handle cap (these are also held on with a little double sided sticky tape, you may have to use a plastic pry tool to remove) removed then just simply slide the handle towards the rear of the vehicle, once it snaps out you will hear a clunk (will explain in a further step). Rotate the handle out to a 90* angle, pull towards you and it should slide all the way out.
5 - This will be much easier to see once you have reached this point. You will need a sturdy piece of fishing string or wire for this step. The clunk you may have heard while sliding the handle back was the handle separating from the internal door linkage. To re install you need to slide the new handle in and catch this linkage.
a - take your string or wire and fold in half and make a loop (you'll need about 2ft). Inside the door you'll see a latch, it is mounted and rotates towards the front of the vehicle and it has 3 prongs (almost has an "E" shaped design). Take your looped string/wire and put it around the middle prong of the latch and pull it forward and hold it there for the next step.
b - place the front of the handle back in exactly at a 90* angle as you did when removing it. (This video shows him putting both front and back of the handle on at the same time, the Silverado's need to be done one part at a time, front first rear second). Rotate the handle once the front is in and put the back half of the handle in. Once the handle is all the way flush and your still pulling on the internal door linkage with your string, slide the handle towards the front of the vehicle until it clicks, seats, or pops.
c - at this point the handle is installed. Close and open the door to ensure proper operation.
6 - Once you have ensured everything is working correctly you can now pull the door handle out slightly (as if you were opening the door), let go of one side of the string and pull the other to slide the string out. Using this string replaces the need for a tool that is not available at this time.
7 - Install door handle cap
8 - Tighten torx bolt
9 - Install black dust cap/cover
AND you're done! Hopefully the next person to tackle this can get us some pictures since I didn't take any.
  • 1 month later...
  • Replies 69
Thanks man. I knew how to get the door handles off, but when I went to slide the body colored handle on I was like "sh!t it's not locking in"!!! Thanks for your step by step instructions.
i used a scrap piece of wire to pull that "E" retainer. literally takes about 5 min per handle once you know what is going on. I've thought about just making a video because it's very easy but some people will be a little frightened to do it because they have not seen it done.
  • 4 weeks later...
Very helpful thread when I changed out the chrome for black. Here are a few pics to go with the instructions by the op.
E shaped
Without square washer
With square washer
You can easily replace your black outside door handles with the chrome or painted optional set. Mine are chrome. The instructions from GM say to remove the door panels but this is not necessary. You can change all 4 in about 30 mins. Someone else on here has a step by step instructions and they are great, but don't try the fishing line they suggest and there is no need to buy the special tool they talk about. You can make your own tool out of a long slim flat screw driver. Just heat it and make a 90 degree bend in it. I have a pic below. Other than a torx bit, that's all you need.
The drivers door is a little tricky due to the lock cylinder, but you can work around it.
Just use the bent screw driver to turn the "E" shaped clip toward you while you push the handle in and toward the front of the truck to snap it in place.
  • 4 weeks later...
Wouldn't using a piece of fishing line be easier and smarter than having to heat up, bend and ruin a good screwdriver? The fishing line trick is supposed to be cheap and disposable for those with stuff laying around the house. lol the advice on some of these forums is crazy..
Where can you buy onyx black door handles at Ebay does not have any where are yall getting your door handles and mirror covers at?
We all go ours from ebay, not sure where else to buy them.
  • 3 weeks later...
I am slightly confused on removing the torx bolt. The video says remove the torx bolt and there is not anything mentioned in the directions regarding not taking it completely out. So can the handle cap come loose without backing the bolt entirely out?
1 - Open door.
Yes. The torx is just holding the one hadle part in place with pressure. Just lossen it while pulling on the small door handle part in the rear. You will feel it coming out and then when the screw is out enough it will come out. Dont remove it all the way.
Thanks, going to attempt this tonight. Any other tricks for making this easier?
No you will be fine. First one took about 5 minutes. Other three took probably 10 minutes all together. Once you do the first one you will cruise along. I was very nervous about hurting my new truck. Don't sweat it though. It is really easy.
PS I used a fishing leader I had laying around.
Thanks, The fishing leader is to loop around the E- prong to pull out of the door and slide the handle in to lock, correct?
Yes. You will see it once you take the handle off. The first picture in post 4 gives you an idea. The handle slides in on the right side of that opening and then back into the clamp which needs to be pulled out a bit for it to slide in.
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,141 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
