35's with the 6.0?
I've got them...its fine..plenty of power etc...i got the hypertech power programmer 3 and fined tuned everything for the 35's...no problems here
What are 285's equivalent to, 33's? If so, you'll definitely notice the difference.
I lost a little off the line performance, and it doesn't kick down out of OD as fast as I'd like it to, but I just couldn't stomach how my truck looked with 245's so the trade off was worth it. And besides, as soon as I make the final determination on what's the best programmer I'll solve all my performance problems once and for all!  :D
What is the biggets you can go on the stock HD alloys??  I thought I saw a 305/70, but not sure if thouse were the sames as the '03 HD alloys.  anyone know what size that is comparable to?
I am getting, seriously between 11-12 with the 35's and the speedo, shifts, all that corrected..i am serious, the truck hauls ass and i have gotten it up to around 115 with no shortage of power
That's pushing your luck. 285/75's on 6.5" rims isn't the wisest choice, but getting a tire even wider will be stressing on the beads an awful lot. Besides, the 70 series will most likely rub somewhere, because my 285's come awfully close on full lock.
Jim...Where do your 285's come closest to rubbing?  Also, what is the backspace you are running?  I've been thinking of getting the Terra Grappler in 305 due to it's 'E' load rating.
The plastic wheel well liner mostly, and the lower valance on the front bumper (but that last bit shouldn't make too much difference for a wider tire, only a larger one).
I'm using the factory alloys, so I don't know what the backspacing number is. But they seem to fit pretty good.
The TG's are awesome tires -- I truly have no complaints with them. When I bought this set there was very few people who had even heard of them, let alone owned any. AAMOF, my local 4wd center had to make a special order to even get them. So I did have some 2nd thoughts -- just like Columbus must have, well what I did wasn't quite that daring -- but I'm glad I bought them. :thumb:
The 285/75's "only" carry a D rating, but they increase the max load by over 10% from the factory rubber, so I think I'll be safe no matter how much weight I put on them (well, up to the limit of the truck anyway).
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
