Air recirculation / fresh air motor - actuator problems; video inside
I have been dealing with this noise on my 2004 Silverado for 8 plus months now. I believe I have it tracked down to the air recirculation / fresh air intake motor/ actuator. When the noise begins, I can temporarily get it to stop by pressing the air recirc button. I dropped the glove box a few days back and was able to see the door opening and closing. The door seems to open and close smoothly, but does pause briefly( maybe a second) before closing all the way. The noise occurs when the door fully closes or fully opens. After opening or closing, a few seconds will pass before you hear the noise in the video.
I have done some reading on this and most of what I have read says the dash needs to be removed/ lifted to replace this part. Being a graduate student and working full time, I really don't have the time to pull the dash.
I received 2 quotes from local a/c shops. One for $350 and one for between $200 and $550, depending on them diagnosing what motor/ actuator they find causing the noise.
Few questions I could use some help with here.
Can this be unplugged to get the noise to stop?
Can I replace the part without pulling/ lifting the dash? It did look awfully tight behind the glove box.
Is there an easier way for me to fix this?
The video below is me toggling the switch back and forth a few times. The video is sideways. My apology but i was laying on the floorboard trying to get a better view.
did you try the battery disconnect thing? ,reconnect ,key on engine off ,let the HVAC do its thing (it moves the doors to learn itself )
Rob, that is really good advice. Just when I think I can't stand to read anymore of your posts lambasting people about not going to the dealership to get their cars repaired you come back and redeem yourself.
I did try this. I disconncted the battery, let it sit for a few minutes, reconnected the battery. However, I started the truck, not key on but engine off. I believe it still cycled everything as I listened and the air was directed through all the different vents before it finally went back to the settings I had the a/c on before I disconnected the battery.
Ty,I wouldn't call it lambasting ,lol
Any other thoughts from any one? Can it be replaced with out pulling the dash?
did you have it diagnosed or scanned yet ?or are you guessing for 2 days labour for nothing?
you are getting ahead of yourself asking worst case for no reason ,,you get me a code and i give you the DTC table or do what ya want ,,,,,
let me know
let me know
What type of scanner would be needed to get a code? The several local shops I called quoted an hours labor to diagnose it. Not sure if there is an alternative.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
