Need help with maintenance
I just bought an 09 silverado 1500 with 75,000 miles on it and i want to do a complete fluid change on it to get it on a schedule. 6.0L 6 speed 4x4
Need the capacities:
engine oil 5w-30???
transmission atf?
diff's
transfercase
anti freeze
power steering 5w-30???
filters and brands to stay away from
2009 CHEVROLET TRUCKS SILVERADO 1500 PICKUP 6.0L 8-cyl Engine Code [Y] L76
CAPACITIES:
Engine, with filter..........6 quarts [1]
Cooling System, Initial Fill..........16.8 quarts
Automatic Transmission, 6L80 Initial Fill..........6 quarts
Automatic Transmission, Total Fill
6 speed 6L80..........12.4 quarts
Differential, 9.5 RingGear Rear..........5.5 pints
Differential, F4WD Front..........3 pints (All Wheel Drive)
Differential, S4WD Front..........3 pints
Differential, 9.25 RingGear Front..........3.6 pints
Differential, 8.6 RingGear Rear..........4.2 pints
Differential, 10.5 RingGear Rear..........5.5 pints
Transfer Case, BW 4485-NR3..........3.2 pints (All Wheel Drive)
Transfer Case, MP 1222, 25,26..........3.2 pints
Transfer Case, MP 1625/1626..........3.2 pints
Transfer Case, MP 3023/3024..........3.2 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....18 ft/lbs
Transfer Case BW4485
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
Transfer Case MP Series
Fill Plug 13 ft/lbs
Drain Plug 13 ft/lbs
Found the info HERE
Engine Oil - 5W-30
Differentials - Synthetic 75W-90
Transmission & Transfer Case - Dexron VI ATF
Power Steering - Power Steering Fluid
    2022LtTbZ71
    2022LtTbZ71
  • Who's Online   5 Members, 1 Anonymous, 1,231 Guests (See full list)
