2014 Sierra 2500HD Denali
So, I just traded in my 2012 Sierra 1500 Denali 6.2 for a new 14' 2500 HD 6.0. I have about 600 miles on it, and want to change it over to synthetic Amsoil 5/30. Is it too early to change? Plan on long trip to ME this week, and would prefer to have synthetic in it.
Any guidance would be appreciated. Thanks,
Jeff
No its not to early. I did my truck at 750 miles and my car had right around 500 miles. Plenty of cars come from the factory with synthetic oil
Jeff
Jeff - interested to know why you switched from a 1500 to 2500. Did you need more HD capability or did you just want something bigger? I am looking at a '14 1500 with the 6.2 motor currently. Your gas mileage must be low compared to the 6.2 you had? Thanks.
The 6.0 in a 3/4 ton gets worse MPG then the 6.2 in a half ton. The 2500 platform is a lot heavier then a half-ton platform.
So, after 700 miles I can tell you that mileage between the 2012 Sierra Denali 1500 with 3:42's vs, the 2014 sierra Denali 2500hd with 3:73's is close. 14' is getting 13.8 vs. the 12' 14.7. Other factor is the 14' does not require premium gas like the 12' 6.2 required. So net, I maybe a head just a bit from a gas cost perspective.
Primary reason for trading the 12' is due to towing limitations/safety. I currently have a 28' enclosed inline aluminum snowmobile trailer. The 12' pulled it fine, but a 1500 is light duty from a suspension and frame standpoint. The 12' 6.2 had no issues towing, but I always felt the the trailer was sometimes more in control instead of the truck. Mind you, I'm not a speed demon, and generally have my wife and kids with me, so safety is number 1 priority.
I actually looked into getting a 14' 1500, but learned from my local dealer that the new 6.2's were slow to be released due to the manufacturer of the new aluminum block having issues. Did not feel like getting a new truck and motor that had not been proven, also, not sure I am a fan of aluminum blocks. I would assume that this would take weight away vs. adding it.
After looking at the 2500hd Denali, there is no comparison in the structural gains in a 2500 vs. 1500. Cost between the two is minimal within 3-6 grand.
Here's a pic of my 1500, I'll load up one on the new one too.. Let me know of you have any other questions.
Jeff
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
