New VMax owner with a question
Bought this truck recently and so far love it! Been enjoying driving it.. until last night I hear a tick noise in a drive through. I thought I might have the dreaded L76 lifter tick, but listening to the valve covers, valve cover bolts, and exhaust manifold ports with a home made stethoscope I didn't hear anything other than normal valvetrain noise, no one cylinder stood out so I'm assuming that's not the issue.
It almost sounds like a serpentine issue until you get under neat the drivers side of the truck and it's very obvious.
I made a video of the noise.
What do you guys think? This LS is a new beast to me, my last Chevy had a TBI 350 in it.
So far I love the truck. Has 63k on the clock and drives super nice. Wife hates the gas mileage but I'm happy with the 13.5-14mpg I've managed so far(hand calculated).
My plan is once I have the maintenance up to date(Dealer says 100k on the transmission fluid... I say yeah right I'll do it myself asap) to get a Black Bear Tune and a Ready Lift leveling kit and drive the heck out of it.
Mine has a similar noise,although a little quieter,been that way since new,I have 45k on it now.
I take it that it's out of powertrain warranty then? Otherwise is take it in but most of the work trucks here do it and have since new
Thanks guys. I have another month left o fmy warranty. I'm going to try and narrow down the noise underneath. It doesn't get faster as the truck revs, almost goes away.
I found the issue... lets see if the dealer steps up and backs up his CPO warranty.
Drivers side rear exhaust manifold bolt is either broke off or missing. I couldn't get up there to see if there was any bolt left in the head. I've only had the truck barely a week off their lot and the dealer in question is supposed to be one of the better Chevy dealers.
Here's the culprit. Definitely broke or missing.
The dealer is going to fix it for me. Once that's done I'll be writing a nice review of them since I planned on writing a nasty one if they didn't. You always hear about the bad, but rarely the good in the dealers.
Spent all of a half an hour at the dealer. They looked at it and sent me off with a free loaner. They're going to pull the manifold, extract the bolt, inspect the manifold and replace if need be, and replace the bolts and gaskets on the drivers side. Decided to have them flush the coolant while they had it in their possession.
I'm going to purchase bolts and a gasket and hope the passenger side bolts come out without too much problem. I want to replace them before they break.
Sounds like a good deal. Free parts and labor are always nice.
My only thought would be if you replace the other side and twist off a bolt head, it can be a pain to do the work. That might be a good thing to do when your out of the warranty period just in case it does break on its own.
Got the truck back. It's a lot quieter. Dealer tech decided to pull the head which also means I have all new gaskets and bolts on that side. They did a good job taking care of me.
Still got a noise that's bugging me. Still can't hear anything with the stethoscope from the valve train or lifters other than "normal". Pulled the belts since I know they both need changing and the tensioner is a little noisy..
I'm hoping it's still exhaust related since it's underneath the truck.
Driving it today I heard a noise similar to a woodpecker chatter or even a muffled jake brake on a semi coming from the engine bay on a deceleration and within 30 seconds the CEL came on. Pulled the code and it read P1174 code(Fuel Trim Cylinder Imbalance). Same code I had when I brought the truck into the dealer. I have an appointment scheduled for Monday to drop it off again.
It's back at the dealer. I hope this stuff gets figured out before my CPO warranty is up :throwup:
I had the chatter noise happen on the way to dealer, it occurred on deceleration from 75 to 70 after passing someone. It happened at the same time as AFM kicked in. Told the dealer this...
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
    • I have a trailer lights checker I plugged into the 7 way connector in the bed of my truck that has the 5th wheel/gooseneck hitch. It gave the camera side view with the turn signal on just like having a trailer connected but it disabled the rear bumper sensors. I would rather have the rear sensors working.
    • You are winning more than battles. You're winning the war!  Nice.
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
