On the news...
pacodiablo
On the news it was said that Osama plans to blow himself up within the next year...sounds like a good riddance if you ask me...it's sad that he will without a doubt take innocents with him, but I would still like to see him dead.
It's always wonderful when these people(serial killers or killers in general included) take themselves out instead of giving us the satisfaction of justice or doing it for them.  Hopefully we'll take care of him before he does himself.
If we were to get him or confirm he's dead, do you guys think it would make the terror stress subside?  I just wonder an exact count of how many people truly follow him.
If you would've asked this a year ago, I might have said yes.
But there's always gonna be a Osama, a Saddam, or whatever, when we get rid of them, there's always gonna be somebody next in line to take their place.
The only true way I can see the threat deteriorate is if we just bomb the #### out of all the troublesome countries until they're just one big sand-dune.  :smash:
And if the UN doesn't like that, tough sh*t.
This could be true if he was alive now.  There is alot of talk of Osama being dead already & we are keeping him "alive" with these tapes to help support the war.  Take the last audio tape just released for example...I'm not sure where I stand on this issue, but I dont rule anything out.  I'll make my decision when all the smoke clears...I usually dont subscribe to these "wild" ideas, but I find it hard that if he really was in Torabora (sp?) that he survived those bombings.
Eric
