Gauge Cluster 03 1500HD
30 1500HD
I have a 03 1500HD LT new body style
I am having some issues with the high beam & door lock (padlock) looking indicator lights staying on when truck is off
hence killing the battery. (red top optima)
I have had my cluster in for recall repair
I have checked the EBM disconnecting 1 at a time to see if problem/indicator lights goes off
I have not checked the ECM yet as it is under battery tray
Does anybody have a clue why this is happening?
Thanks
Mike
Additional added 02/10/14
Does anyone have an issue like this or heard of this?
I take my keys out truck off
and the high beam (blue) indicator light is illuminated and so is the(red) (padlock) Doorlock indicator
light on gauge cluster. not bright just faintly illuminated, but enough to kill battery after 3 weeks parked.
I have had my dash in for recall, worked great till I parked after hunting/camping/towing season
theses 2 indicator lights drained my red top optima. Now this issue has arised in gauge cluster
I have checked the BCM under column unplug 1 at a time to see if they go out still on. im thinking its the ECM under battery tray because im having a low idle issue.
I am a marine tech/mech working on mercury/mercruiser Sea-Ray, Boston Whaler Boats
Sea-Ray uses gm modified for marine engines only. form 3.0L 4cyl to 496-502 V-8 blocks
of coarse the boats don't have theses gauge cluster or BCMs under steering column
But they do have the ECMs but are mercuiser modified and controlled
just kinda stumped on this issue
Thanks for any feedback
  • 1 month later...
Just got my trk back for Coopers Auto Repair
They found the circuit board in gauge cluster was bad $740 to repair
no lights staying on all good.
Chevrolet screwed all ( late 02)-03-06-(07 early) truck buyers when they put these crappy circuit boards and clusters in our trucks these years
Like A Rock (Bunch of Rocks)
Don't know why there was not a more extensive class action law suit against GM/Chevrolet about theses junk gauge clusters
I still Love my Truck 03 1500HD LT Crew
But come on GM/Chevrolet Step up do the right thing stand behind your product!!!!!
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
