Tekonsha Sentinal Brake Controller
This was my controller in the last two Dodge trucks. At the time I purchased it, this model was one step below the Prodigy.
Its an inertial-based system, the harder it feels you stopping, the harder it applies the trailer brakes. Pretty simple to setup, pretty much a set and forget. Its been sitting in the garage since I bought the Silverado, but it worked fine when it was pulled.
Asking $20 and shipping.
