Did my water pump go bad?
For several years I know I've had a very, very small leak somehwere in my system. On hot days while sitting and idling you could smell antifreeze if you had the hood up but never see evidence of a leak. I add maybe a half gallon a year at most to the overflow.
Today I went to run to lunch and noticed what looked like a lot of water under the truck. I added about 3/4 gallon of water just to get the level to where a little remained in the overflow. Upon inspection of the engine, I found the bottom frame crossmember completely wet. the water pump housing looked completely dry. after running the truck around the block for a while I pulled back in and found some wet spots on the hoses in a pattern that looked as if water had dripped on to the belt and sprayed off onto whatever was in the area as the belt went around a pulley. I also saw evidence of spray on the liner under the hood as well as the fuse box.
I don't see any leaks on the hoses, from the thermostat housing, or anywhere else. Given that the coolant appears to be hitting the belt and the front of the engine looks dry, is it safe to assume that the water pump bearings or seals have gone bad and the coolant is leaking from the front of the pump? I'm used the old style small block water pumps where you could easily see where coolant was coming from. Now I'm not so sure. Given this will be a $200 DIY fix I want to be reasonably sure the pump is the issue. (pump, 2 hoses, thermostat, antifreeze, and possibly a belt)
Also, any special tips on replacing the pump? Seems fairly straightforward in that you remove the radiator shroud, air intake for room, belt, hoses, then bolts.
What year and type of vehicle? Gaskets have been known to leak also. Look on youtube for videos of replacement procedure
Sorry, it is an 04 with the 5.3. (Sierra extended cab 2wd)
Strangly enough there is a spot on the very top of the pump housing hat has a glob of dried out antifreeze. there is no seam there, seal or anything around it that could drip water there.
there are two different pumps showing. One with a 2" outlet and one with a 1.9" outlet. i'm assuming the larger one will be the correct fit but not 100% sure. Rock auto has replacement pumps at a great price.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
