Soft Tonneau Advice?
MD Chevy
access lorado installed last nite excellent fit and finish 385 bucks from amazon
I've got an Access Lorado on my Sierra, and had one on my 2008 silverado as well. Line-X liner on the Silverado and no issues at all. I'll be getting Line-X on the Sierra in the spring as well, and don't expect any problems with it either.
Thanks! That's what I'm looking for! Why did you opt for the laredo? I'm looking at the tonnosport.
Bed liner, Trwtow?
bed rug ive ran this combo on my last 3 truck works perfect for me
I wanted the improved hardware (tension adjustment, release, wider velcro rail and weather sealing) as well as lifetime warranty vs 3 year.
Thanks for the response. I think I'm going to meet in the middle and get the vanish.
I decided to get the access lorado. It was a little more than I wanted to spend but with some advice from trwtow and a little research, I think it will be better for what I want and the lifetime warranty will be nice reassurance too!
let us know how u like it after u get it installed
Installed it last night. Like the looks and functionality this far. The weather strip on the back lacked proper adhesion. I had to use some gorilla glue to get it down. Pretty sure I screwed it up though when I put the cover on. Not sure on water tightness, but I think it will keep my golf clubs dry enough. Going to drive truck tomorrow so I will see how it rides in the wind! Overall I'm pretty satisfied.
Truxedo lo pro. Nothing better period. My current truck came with an extang revolution and it's no where near as nice as the truxedo a have been for me
    HWN808
    HWN808
  • Who's Online   3 Members, 1 Anonymous, 945 Guests (See full list)
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
