Parts on Silverados that Switch
I have a 2007 Silverado 1500 4wd classic extended cab. Looking to get the steering wheel controls on the steering wheel and the power folding mirrors to convert these items.
Found a 2006 2500 extended cab with 6.0 that was wrecked with good wheel and column to get for 125 with the wheel and all. No airbag which is no big deal as I would use my existing..
Also, looking at getting the DL3 switch from the drivers door to convert that as well.
Floor mats as well for my newly acquired rig.
The big question is will the 2006 2500 parts fit onto the 2007 classic 1500 truck? Are they the same?
Steering column mainly the steering wheel and coil spring is what I am after to convert over, and the door switch.
Is there a web site I can go find these items for future reference?
Thanks for input on this topic. :help:
