Adjustable Pedals
siwik66
I just purchased a 2014 sierra slt and got adjustable pedals. I was wondering when you push on the button down or up the pedals should move correct? I am having issues with the pedals not moving at all and when you push the button down or up it just makes a clicking noise. So I am wondering if its NFG?? Also the dealer did a undercoating (which i didnt want and thank god they didnt charge me) and it is very soft like it hasn't cured yet and when u touch it u can leave your finger print in it
I have not tried to adjust mine while driving so maybe before you take it in just test it while stopped with your truck in Park just to be sure it is not locked out when driving!!!!!! Other than that there is a issue that the dealer must get fixed for you.
Undercoating is factory applied it is a wax coating and stays soft, it is a GM truck thing. Dealers have been trying to rip people off for years with the protection packages they are mostly bogus and just trying to inflate the sales price for no value added. Enjoy your new truck can you post any Pictures?
Welcome, I'm from SK too. My pedals work fine moving or stationary. I'd be curious to know your fuel economy in these parts. Mine had been awful and I can only guess it's the cold.
Sent from my SGH-I747M using Tapatalk
  • 3 years later...
Same thing happening to my 2015 yukon. What was the fix here?
