So long Chevy, hello ram.
joshw1303
Higher trim trucks have LEDs for turn signals and such I think.
  • Replies 43
Looks good in white!
Anyone know why the Ram has two different Styles of headlight? I thought at first one was HID only, but that style also has halogen bulbs if you look at the ramtrucks site.
One style is like the one in this thread, but the other has a short and wide turn signal/ parking light.
You need to move up to sport or higher trim to get hid and led turn signals and break lights. All other trucks get regular lamps. I don't mind the regular lights. Still look very good. Also it's an option on SLT to get dual exhaust. I wish the outdoorsman had the option but I understand why it doesn't have dual exhaust.
Sent from my LG-D803 using Tapatalk
Ya its sweet, here some other shots.
Congrats on the new truck! I have been considering jumping ship over to the Ram as well, really like the Black Express they have out right now.
You need to move up to sport or higher trim to get hid and led turn signals and break lights. All other trucks get regular lamps. I don't mind the regular lights. Still look very good. Also it's an option on SLT to get dual exhaust. I wish the outdoorsman had the option but I understand why it doesn't have dual exhaust. Sent from my LG-D803 using Tapatalk
The black ram express package has the sport headlights and led tail lights.
Good looking truck man.
How smooth is that 8 speed transmission? Does it seem to shift a lot?
Ya it shifts but it's butter smooth! Next thing you know, you're at 100kmh lol. It is a fantastic transmission. One of the features I live about the truck. The power train is great.
how does that rear end feel with the coils instead of leafs
?? Rear end feels planted got most part. Smooth over pavement. Takes pot holes well.
Power is always on tap at any speed with that zf 8 speed. If the 6.2l had the zf 8 speed. Dear Lord the power lol.
Nice! My brother wants a Ram bad right now too! Hope they treat your family with thousands of trouble free miles!
