My 2014 LTZ-Z71 6.2 ordered
2014-Chevrolet-Silverado-interior_zpsfa1
I placed an order on Monday at my local dealer in Washington State for a new Silverado. I want it to be fully loaded. I am wondering if I'm forgetting anything. If I'm overlooking even the smallest item, please let me know. Of course I'm less concerned about 'dealer installed' items.
2014 LTZ-Z71 6.2 4x4 Crew Cab - short box
20" wheels - 3.42 axle - sunroof - rear slider
LTZ Plus Package - Nav - Driver Alert Package
Heated/cooled buckets - telescoping steering column
Trailer brake controller - retractable side step
LED cargo lighting - Movable cargo tie downs
You want to order the dealer installed stuff at the time you order. Otherwise you pay full price for those things.
I ordered the exact truck in December and received it in February. Rear slider was deleted at the time. I didn't get the driver alert package. Not something I need for 800 bucks.
Great truck!
desert,
I understand that ordering a new vehicle can be overwhelming. I just wanted to stop by and let you know that GM Customer Care is here if you have any questions or concerns about the ordering process. We can even provide you with updates on your order status. Feel free to private message me at any time.
Jennifer T.
GM Customer Care
'Updates on my order status' ? .......I like the sound of that...... Yes please keep me informed....Thank you ! :happysad:
desert,
Great! I also saw your private message and I am happy to provide you with updates on your order status. All I need is for you to either private message me or email me at [email protected] including attention Jennifer T. in the subject line your order number.
Looking forward to assisting you,
Jennifer T.
GM Customer Care
I ordered 3/3 14 LTZ/2lz Z71 6.2 DC, NAV, rear slider, 20 chrome pretty much all the same as you except moonroof, not available for me.
I did order rpo code cgn which is the spray on bed liner
I believe it's generally considered a 'dealer installed' option. Apparently pricing is better when these items are included in a factory order. Also I heard that it would be installed at the factory if it's on your order, hence it's on my order. (one less thing to mess with when the truck arrives) As an afterthought I think truck owners can buy one for self install or have the dealer put one on for you. Mounts on either side in front of rear wheel. Probably won't work with side steps.
54k? These trucks must be a lot cheaper in other parts of the country.. Here in Los Angeles I see them everywhere.. hell I was looking for a 55 Pontiac and the one I bought had a 14 Silverado in the background of the picture.. Then I saw another one parked right next to mine yesterday when I got out of my office.. and another one a day before, and so on. I know it took me THREE days, walking out about 5 times, and buying on the last day of the month just to get 7k off MSRP.. This was on Halloween and putting down 20k in cash too. Some of the deals I see here are either very exaggerated or I should have taken a trip and bought in another state...
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 801 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
