Programming 04 silverado trans temp gauge
Does anyone the the procedure the dealer need to know on how to turn the trans temp gauge on in the cluster,I added the stepper motor and the overly.I wanted tkeep from sending it off. My chevy dealer will try it they just dont know exactly where to start.
I swapped in a 2500HD cluster and mine worked with no programming.
It should have been plug n play with no programming. Perhaps you should double check your work
Some clusters did not have to be programmed and some do, unfortunately I think mine does,I have checked my work and all seems good,The speedometer shops have a way of turning the trans temp gauge on,I was wanting to know the process on how he dealer can do with a tech 2.
I guess I've been lucky with the 40 or so I've worked on, have worked with no programming. Don't know the dealer procedure
Maby I am doing something wrong,my cluster is one that has been reprogammed befor to turn the DIC and radio control on the steering wheel,My truck is an 04 ls,I dont know if that matters,so you have just soldered the stepper motor in and it worked,do you remember if the light was already in or not or if it made a difference,I soldered the light in mine and that part works,any help with this I do appreciate.
No light, no nothing in the position. We added them to all our trucks 7 or 8 years ago. I have heard second hand stories of people not having them work after adding the stepper. You might try searching the site for threads with this problem
Z71_AST went through the same issue. Not sure if he ever resolved it.
I have talked to a couple of rebuilders and they have said some do and some dont work without programming,I was just wanting to know what procedure to do at the dealer if possible without having to ship it off.
