Question for moderator
Zane
Hi,
The dates for last action are out of sequence ie: 9/17 are on top followed by 9/18 and than back to 9/17. Little bug?:0
I see.
the top three posts are "pinned" posts, and they sort from the top down, the rest of the posts sort from the bottom up.
Hope that helps!
:devil::D
Quote from LT, posted on Sep. 18 2001,9:23
Thanks Mervz,
I figured that out after I posted but I couldn't retract it. I was sleeping. :devil:
No problem! I clears things up for other people. :D
