Has anyone got an extra PCM?
Crooks
I have been told by Trailbazer SS owners the way around the lack of warrenty when you get a tune is to get another pcm and tune it. If there is a issue where your truck has to be scaned put your old pcm in. Has anyone on here gotten an extra PCM?
It has been said that it doesnt work on the 2014s and you cant swap the tcm on a 2014
What he said, only dealer can marry a new PCM to your vehicle, that was so last year.... Lol
Correct, not able to swap ECM on these series trucks without going to the dealer which means GM will know you swapped the ECM. The TCM is located inside of the transmission and not something that can be swapped easily.
  • 3 weeks later...
Same as everyone else stated. The dealership I was talking to said they started to put a stop to this on the corvettes & camaros; now all the vehicles.
  • 3 weeks later...
i did this on my 2012 and was looking forward to swapping ecm on my 2014 ,on my 2012 i had gone to a local shop that had the gm scan tool and they married the spare ecm to my truck ,dam!!!! any way around warranty concerns ?
Nope, if you are worried about warranty issues in the new K2 trucks I would not tune the ECM. GM will know it has been tuned this time if they look, the ECM has a flash counter and GM knows where the flash counter should be, if you are ahead of it they will pull a copy of the calibration and compare it to stock. Then you can say bye-bye to your powertrain warranty.
This is all only if you bring the truck in for something that gets into major repairs of the powertrain.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 521 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
