Good morning All,
I have an '06 Chevy Silverado 2500HD, LBZ, CCSB, LT3 truck, and it's giving me some grief. I had a bunch of intermittent issues all start at once. Below is a list:
1) Fuel, Temp, Oil, and Volt meter fail to off position.
2) Battery and ABS lights illuminate
3) “Service 4WD” message is displayed
4) Radio loses power or displays "LOCKED"
5) Power windows and lock do not work
6) Headlights turn on, even in full sunlight
7) Opening door does not always turn off RAP or IPC
8) HVAC controls still work
9) Security shut down happens sometimes (starts but dies 2 seconds later)
10) Heated seats do not work
11) Dome lights do not turn on when opening the door
12) Radio lights on with the ignition off (they were the only lights on in the truck)
13) Turning on the parking or headlights does not immediately turn on instrument lights (there is a 5-20 second delay)
14) Window switches may or may not be lit
15) Truck starts and runs fine (when it is not shut down by security system)
What I've found so far is some of the wires at connector C100 had been chewed by a mouse. I have cut and soldered to repair the bad sections. I have tried an ignition switch, BCM, and cleaning up some of the grounds (front left frame rail, under drivers door, G203 at A-pillar). Nothing seems to have made any improvement.
Other things that I've done are reverted to stock from level 4 with my PPE tuner, disconnected the Viper alarm system and XK01 data line interface. I've been running the truck this way for 6 years, so I doubt any of those are the problem. However, I wanted to eliminate them as a source of issues.
I was thinking that the BCM may be flaking out, but a replacement exhibited the exact same issues. Since this is intermittent, and happened suddenly, it made sense. However, after finding the chewed wires under the fuse panel, I'm not so sure anymore.
Any help that anyone can offer would be most greatly appreciated.
Thank you.
Does it show up now?
I was just checking out everything in the engine compartment and found a chaffed wire on the ECM plug. It looked like the two harnesses to the ECM were rubbing together. I didn't see anything that would have been making contact. So, I just wrapped it in tape and moved on to the next set of connectors.
I wound up unplugging and reseating all of the major underhood connectors (ECM, PCM/TCM, and engine harness). They all looked good, with the exception of the top plug on the engine. That one had a few wires that were nibbled on, but not shorting. I think I'll probably liquid tape those just to seal them up.
After I disconnected and reseated everything, I tried starting the truck. It started, ran, and everything worked. I only let it run for 10 minutes, but everything was good. However, after 3 or 4 minutes the security light lit up. I'm not sure what that's telling me, but when I shut it off and tried to restart, it still worked.
I've never seen the security light before Monday.
Next up I tried to pull the B and U codes. No dice. I still get a communication failure. Although, I can now pull and reset the P codes. I had two history codes for glow plugs (I replaced three in December), and a P0650 (that I no doubt set when I was messing with the IPC.
I'm still at a loss here...
Sounds like lots of wiring problems. The underhood fuse block is one place mice love to get into. If you haven't checked underside of that fuse panel I would check there next.
Sent from my LGL86C using Tapatalk
Yep, I found a couple there and repaired them already.
Are there any "common" spots to look for with respect to wiring damage? I'm still having a communications error with the ABS and SRS modules.
  • 4 years later...
Did you ever figure out the issue? I'm having the same exact thing happen with my LB7
  • 2 years later...
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 291 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
